Reload this Page >
Bob Cat Copy Falcon 120 Jet
Old 09-11-2019, 09:20 AM
  #5001
john491
My Feedback: (13)
Look into the wing through one of the holes in the root and see which way the shear web is installed. They should be vertical. Some of the early ones had webbing installed with the grain horizontal. It's pretty much a total rebuild of the wings if they are wrong.
There are a couple of sources for fuel tanks made specifically for the Falcon. Pretty much have to remove all the rear formers to get it in but they fit.
Some needed the motor platform reinforced, I didn't on mine.
They fly fairly well if balanced properly, a lot of fun.
I'm using a P-60 on the version I'm flying.
John
Old 09-11-2019, 01:36 PM
  #5002
alasdair
alasdair's Avatar
My first Falcon 120 was 60 powered (a Wren 54 Mk3 rated 63N, 14 lb). That was perfectly adequate for a good performance and manoeuvrability.
I used the KISS principle: fixed gear, big battery well forward and no ballast, standard servos, single large glass fibre tank (made myself, 2.2 litre).
The only reinforcing I did was a little epoxy mixer with Kevlar fibres around the blind nuts that held the booms to the wings, and I changed to steel bolts.
I shortened the legs to reduce stress on the mountings.
The weight was about 6 kg, 13 pounds.
My first eventually hit a fence. My second one (still in box) will be similar.
Old 09-11-2019, 03:35 PM
  #5003
SeaHawk-RCU
Originally Posted by Kim Couturier
Wow, long thread! I have a question. I have a chance to pick up a red falcon 120. It does not appear to be carbon fiber reinforced. I have no skills that would allow me to do “ mods” to the kit for turbine use. I have read several threads that say you can, in fact, fly these without the mods if you keep the power to a 60 size turbine, and don’t fly at full throttle for extended time, or when turning the jet at speed. What do you guys think? I’ve had a couple before, and they were a nice , small jet I could haul in my Durango and not have to pull my trailer....good off my local grass field...my other jets are bigger, and composite. I would appreciate any feed back...
Hello Kim,
I am on my 6th Falcon 1.20 and I love them. All have been the gen 1 or 2 (no carbon fibre) and I have found that at the minimum you will have to reinforce/re-glue the u/c mounts. I have photos of the process somewhere in this forum. My first Falcon had no mods done, was fitted with a Kingtech K80 and electric retracts. The second landing (not hard) resulted in the left hand main coming out of the wing, bearers and all. Inspection of the other side showed that the flour and water glue they used was about to let go as well. After fixing that problem and replacing the 22mm wing joining tube (original too short) it went on to have 70+ flights before I sold it to buy another.
Since number 2 and beyond I do the following with each new Falcon before flying.
1. Do the u/c bearer mod. (at the same time I change the angle of the bearers to allow fitting of trailing arm u/c legs,, note trailing ARM not trailing link,,, )
2. Measure the exact length of wing joiner tube required and replace the original.
3. Remove/reshape rear fuse formers to accept after market conformal fuel tank (2.6l)
4. If the wings are open bay structure I remove the covering and fully sheet them. (It is my personal choice to do so.)
5. Throw away all nylon wing/boom bolts and replace with steel.
6. I also fit the flaps upside down and surface hinge them to give added deflection.
You don't need to do most of these if you don't want but I suggest you re-glue the u/c bearers as a minimum.
Regards
Col
Old 11-19-2019, 01:29 AM
  #5004
BashaBolla
Default Falcon 120 on a 45N Turbine ?
I have a Falcon 120 with a Wren 80 on the back. It goes like stink and is a joy to fly. Problem is I want the engine ( and the heavy Electron retracts and brakes )for another plane .
I have a new Xicoy X45 that I am thinking of using on the Falcon. I will use some light cheapo HK retract units and some wire legs with no brakes to save weight . Fuel tank is currently a 2L pop bottle but will be substituted for a 1L bottle to save weight
Has anyone flown one of these on a 45N turbine ?
Old 11-19-2019, 08:08 AM
  #5005
Terry Holston
Terry Holston's Avatar
I don't know where in the world you are, but if you are in the US you need to keep the brakes to be in compliance with AMA rules. Just a heads up . As to if the 45 will fly it I see no reason why not. It will be lighter with the 45 and brakes won't add that much weight.
Have fun.
Old 11-19-2019, 08:41 AM
  #5006
BashaBolla
Thanks Terry...not in the US so no need for brakes :-))….I too can see no reason why not ..the X45 is really light and I think ,with the reduced weight, the package should be good....was just wondering if anyone actually flies one of these with a 45 ? ( reality as opposed to theory
Old 11-20-2019, 11:31 PM
  #5007
Boomerang1
Boomerang1's Avatar
Not an X-45 but a friend flew one with a Wren 44 Gold turbine.
Not a wonderful result, the Falcon 120 is a big, draggy aircraft & it had to fly at high throttle
settings to make headway & was a slow upwind, fast downwind model. While it was light
it would waft around & not fly jet like at all. At least take off & landing speeds were low.
He only flew it twice & bent the crappy standard wire undercarriage legs on the second landing.
At this point he lost interest in it, removed the gear & engine & gave it away.
Old 11-21-2019, 07:01 AM
  #5008
BashaBolla
Thanks Boomerang......food for thought !!
It is quite a "slippery" airframe with the Wren80 installed....fast and takes quite a bit of slowing down ..I tend to fly on about 1/2 throttle most of the time unless I want a bit of an adrenaline rush :-) ...but I too fear I may have to give it max beans all the time with just a 45 …..and I really don't want it wobbling about in the air and struggling like the old IC Ducted Fans used to.. ..so..perhaps this will be one idea I should shelve !
Old 01-23-2020, 07:24 PM
  #5009
warhog
My Feedback: (10)
Which
version of the Super Falcon 120 has solid red covering on top and completely white covering on the bottom?
Old 05-28-2020, 07:12 PM
  #5010
Dkat
Thumbs up Need info help with Falcon 120 plz....
Originally Posted by seanreit
It's a bit small for my taste.
Hi I recently acquired a falcon120 from an auction and have never worked on an R/C plane and was hoping you may be able to help me identify the parts and see what maybe missing or if it is worth messing with. I would appreciate any help you are willing to give, Thanks for your time in advance. Dell Howard (Dkat)
Old 05-28-2020, 07:58 PM
  #5011
SeaHawk-RCU
It isn't really the right airframe for a first time builder/flyer but if you post pictures of what you have we may be able to help out.
Col
Old 05-28-2020, 10:33 PM
  #5012
Dkat
Default You are right about the level of it....
I tried to list everything that had came with the model and am sending it to you. I wish I knew more but having to learn as I go and don't know if this is worth the time and expense to pursue...
I hope this attached so you can see it, if not let me know and I will redo......Thanks
File Type: doc
Old 05-28-2020, 11:35 PM
  #5013
SeaHawk-RCU
That is a pretty good list. The only thing you might be missing are the large and small aluminium wing joining tubes. 22mm and 10mm if I remember. You have a lot of extras there that didn't come with the original kit. If you didn't pay too much then you have a good deal.
The model itself though is not suitable for a learner pilot or builder.
Here are some of my 1.20s
Old 07-09-2020, 07:40 AM
  #5014
alasdair
alasdair's Avatar
HELP NEEDED
I built and flew one of these years ago on a Wren54 and it flew great. Until on day it met a fence.
I bought a new kit and put it in storage. Now I'm thinking of building it, I cannot find any note of reference to the amount of up elevator needed for trim.
Can anyone tell me please, how much up elevator is needed to trim it out?
Old 07-09-2020, 10:00 AM
  #5015
Xairflyer
Xairflyer's Avatar
I dont have any in my navycat and I dont remember putting any on the falcon I built either, are you thinking alister its a tail incidence issue? I would need to put mine together to double check but cant remember anything about this, my model trimming has always been if it has up elevator trimmed in then its bit nose heavy, I know my main battery is further back now than when I first flew it.
Old 07-09-2020, 11:13 AM
  #5016
alasdair
alasdair's Avatar
Thanks for the quick response Xairflyer,
The photos of my old model definately show the elevator set up from the flat bottom of the section by a large amount. But I can't measure it off the photos. And I can't find any written information in my notes.
If you lay a ruler along the flat bottom of the tail, how much gap would there be between the ruler and the TE of the elevator?
There must be some! surely?
I always thought that the flat bottom section was quite wrong aerodynamically, but it's convenient and kind of works. The model flew very well. It just looks wrong.
I'll build the new one with the kit tailplane, but may change it to a symmetrical section at some time.
I don't think it is a building error. I used all the kit parts and they fitted very well. I was hoping somebody more organised than myself would know. Or have one handy.
Old 07-09-2020, 11:16 AM
  #5017
john491
My Feedback: (13)
If it is balanced properly you do not need any elevator trim, except with the flaps. The elevator is trimmed when a straight edge across the TOP surface of the elevator is flush. A bit of down thrust on the turbine as well, about 3-5 degrees. The usually accepted CG is about 13 in. from the leading edge at the fuse.
John
The following 2 users liked this post by john491:
alasdair (07-09-2020), bhouin (02-07-2021)
Old 07-09-2020, 11:23 AM
  #5018
joeflyer
My Feedback: (48)
Like John's, my elevator was flush with the top of the stab. I also had 5 degrees of down thrust and CG at 13".
Old 07-09-2020, 11:28 AM
  #5019
alasdair
alasdair's Avatar
Thank you to you both.
My model is a Falcon, but I posted the question in the Tornado thread as well as I knew they were geometrically similar, but the Tornado is newer.
Your answers are precise and helpful.
Alasdair
Old 07-10-2020, 05:53 AM
  #5020
Xairflyer
Xairflyer's Avatar
yes as far as I remember it would be more inline with top surface than bottom
Old 07-10-2020, 05:28 PM
  #5021
SeaHawk-RCU
I like mine a little nose heavy so mine has a little up trim. Just set it with the methods above and maiden it. I much prefer to be holding back stick while trimming on a maiden than pushing forward. My latest Falcon has about 1/8th inch of down elevator with full flap.
Col
Old 10-05-2020, 10:38 AM
  #5022
sweetpea01
My Feedback: (10)
I've been off and on (mostly off) working on my Falcon 120. Honestly it needs to get finished so I'm putting it on the table for this winter. I no longer have a turbine for it as I put the JC Rabbit VT-90 (propane start) in my TopRC Cougar that hopefully I will maiden any day now. Open to new ideas for this powerplant. Probably want another JC or Kingtech though, not opposed to lightly used.
Questions for the experts as I've lost some of my notes over the years
-Throws for all surfaces even flaps?
-elevator throw when flaps are deployed?
-Where is the CG measured from and located?
I had the Hatch redone over the summer by a friend so its time to start glassing the wings and assembly prior to paint.
Old 12-08-2020, 01:12 AM
  #5023
i3dm
My Feedback: (51)
Guys,
can you please remind me whats the recommended CG for the falcon 120 jet? is 13" generally considered the best point?
Old 12-08-2020, 07:17 AM
  #5024
CARS II
My Feedback: (7)
CARS II's Avatar
Yeap! 13" was the CG given to me, I've confirmed it, CG is given on of 126.
Old 02-07-2021, 06:51 AM
  #5025
airborn900
My Feedback: (25)
My Navycat build. Just finished. Going to maiden in 2 weeks. Empty weight is 17.75lb. Does that seem close?
dhamultun (02-07-2021)
