Jetlegend/BVM 1:5 F16 PNP
Old 12-02-2016, 11:28 PM
jeff sewell
Default Jetlegend/BVM 1:5 F16 PNP
I received my 1:5 F16 some time back and have finally flown it. A non event really; just 2 clicks of up-trim was needed but everything worked as it should. Landing was straight forward too; I started way higher than I would consider for my 1:6 F16, expecting it to go straight past, but to my surprise it slowed down really well and landed and rolled out in front of me. It looks great in the air and felt solid in flight. My set up uses a Jeti DS16/24, CB200, no gyro and CG 25mm back from factory.
Turbine is a Merlin M200XBL which powers it extremely well. I'll try and get video on my next outing but for now here are some images...
Cheers
Jeff
Name:	F16 WEB 1.jpg
ID:	2192062   Click image for larger version
Name:	F16 WEB 2.jpg
ID:	2192063   Click image for larger version
Name:	F16 WEB 3.jpg
ID:	2192064   Click image for larger version
Name:	F16 WEB 8.jpg
ID:	2192065   Click image for larger version
Name:	F16 WEB 9.jpg
ID:	2192066   Click image for larger version
Name:	F16 WEB 12.jpg
ID:	2192067   Click image for larger version
Name:	F16 WEB 13.jpg
ID:	2192068   Click image for larger version
Name:	F16 WEB 15.jpg
Name:	F16 WEB 5.jpg
Old 12-03-2016, 02:57 AM
JP-1
Jeff,
That looks really nice, looking forward to the video.
Is that Elvingdon by any chance? the Pan looks familiar
Old 12-03-2016, 03:31 AM
Mark Vandervelden
Mark Vandervelden's Avatar
Glad to here it went well and nice to finally see exactly which colours you went for, if you can call "grey" a colour ;-)
As soon as I get a chance ill add some pictures of my one.
Old 12-03-2016, 04:58 AM
JohnMac
JohnMac's Avatar
Well done Jeff, It looked really good.
John
Old 12-03-2016, 05:41 AM
jeff sewell
Thanks guys!
Yeah - Elvington - great site!
At least it's not Chunderbirds - I mean that's the chav burberry handbag of colour schemes! (to all who may be offended - it's an ongoing joke between Mark and I - I actually like T'Birds!)
Jeff
Old 12-03-2016, 11:45 AM
Mikey5547
Looks great! How much is it for pnp version? Also does it break down easy for transport?
Old 12-03-2016, 12:07 PM
Scott Douglas
Scott Douglas's Avatar
Location: Hamilton, Scotland & La Roche Bernard, France
Hi Jeff
That looks superb! Any news on the F18 on the JetLegend homepage?
Old 12-04-2016, 02:27 AM
Newton5019
That looks mega Jeff
Toby
Old 12-04-2016, 09:48 AM
jeff sewell
Mikey,
You have to go through BVM or GJC if you are in the 'States - if your in God's country then drop me a PM!
It breaks down to what I call a 'sausage', i.e. no stabs of fin. The stabs are plug-on with a slot which directly engages the servo ball so no aligning on assembly. Potentially it could break down via the split in the fuselage too.
Scott,
The F18 PNP is available and it has the same nice build that my F16 has. Drop me a line if you're interested!
Toby,
Thanks - hoping to get out a bit more next year with this jet.
Cheers
Jeff
Old 12-04-2016, 10:24 AM
Newton5019
Great stuff Jeff look forward to catching up again, do you have any more info from the factory about the mirage yet ? Drop tanks availible etc ?
Cheers
Toby
Old 12-04-2016, 12:33 PM
jeff sewell
Hey Toby,
I can order them now (got the first coming soon hopefully for Mark V.) but not sure on ordinance packs yet - I'll ask...
Jeff
Old 12-05-2016, 03:16 AM
Scott Douglas
Originally Posted by jeff sewell
Mikey,
Scott,
Toby,
Cheers
Jeff
Thanks mate I will do. Probably early next year if work ever gives me a minute!
Old 12-05-2016, 10:52 AM
Newton5019
Hey Toby,
Jeff
Thanks Jeff, be great if they did do them, is it the same case of pick your colour scheme ?
toby
Old 12-08-2016, 10:42 PM
more
Which type of setting do you use?Flaperon or Taileron?
Old 12-09-2016, 01:18 AM
jeff sewell
Toby, they currently don't manufacture an ordinance pack for the Mirage F1 and yes - pick your scheme! Make sure it's from an actual F1 though as 'unusual alternatives' are not recommended by the factory.
I use flaperon as a rule; never been a big fan of taileron! I fly my JL G2 1:6 F16 in flaperon mode (for about 200 hundred flights) and personally find the control authority very good. Some people like taileron though...
Jeff
Old 12-09-2016, 11:36 PM
Newton5019
Thanks For finding out Jeff,
now to decide a scheme!
Toby
Old 12-16-2016, 04:27 AM
General Jake
General Jake's Avatar
Every video I saw of the 1/5 scale PNP BVM F-16 seems to have some "tail wagging" going on. Did you encounter that?
Old 12-16-2016, 09:34 AM
jeff sewell
Only cross-wind, which is to be only expected, but otherwise straight and true! A gyro may help...
Old 12-16-2016, 11:02 AM
Mark Vandervelden
Only had a hand full of flights on mine, a couple by myself and two further flights by some well known and skilled pilots wanting to experience this new airframe first hand.
Every flight so far has been rock steady, saying that the weather conditions were very good on both outings with only a hint of crosswind.
I have never flown a "Bad" F16 and I have flown quite a few, they seem to be an inherently good aerodynamic shape?
Two things I have tought myself on F16,s is I do try not to play with the rudder to much on the flare wile landing and defiantly avoid turning too soon once on the ground until the speed bleeds right off. (good practice on most airframes)
"Apparently the full size suffers the same trates"
Now if we were talking about my L39 or Alpha Jet they are another story, they defiantly get a wiggle on in turbulence :-)
"But" with Gyros becoming the norm rather than an exception now its all going to become a bit academic in any case?
I do not use Gyros myself in my jets just yet but as soon as the Jeti "Assist" becomes readily available I can see no down side to fitting them to everything I own. I certainly look forward to flying my Alpha with one as its a bit untidy on windy days!
Old 12-24-2016, 11:09 AM
Mikey5547
Sorry that it's a bit off topic but wasn't sure where to ask but will jetlegend be doing a PNP version of the 1/8th F15b?
Old 12-28-2016, 03:33 AM
jeff sewell
Hi,
Not sure as they keep everything very low key but the next is a large F18-C. I understand there is also an F104 at 3.5m and a large F4 somewhere down the line.
Jeff
Old 12-28-2016, 04:59 AM
Mikey5547
Hi,
Jeff
Hi Jeff
Thought it might be a long shot but oh well maybe in the future. Exciting news about the F18 and the others... will keep a eye out for sure! Thanks
Old 12-31-2016, 12:30 PM
Doug Cronkhite
My Feedback: (34)
I like the 16 in the GD demonstrator colors a lot.. hmmmm
Old 01-02-2017, 12:44 PM
jeff sewell
My F16 landing here: https://youtu.be/0X4Ax-lrt54
The landing circuit is quite small, no flap used either...
Old 01-02-2017, 02:24 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Very nice landing. I finally finish repairing mine from a runway incursion at GA jets last year. I taxied it yesterday and hope to find a paved runway on a good weekend to fly it again.
