Jet building services
Old 11-30-2016, 12:27 PM
vquick
My Feedback: (71)
vquick's Avatar
Default Jet building services
My name is Victor Diaz and I will like to offer my services for Jet Building lots of people Know me in the pattern community I build many planes for them also I have 45 years his hobby and over 30 in building experience I live in the Panhandle area in Florida. I been flying Jets for the last 2 years and participating in most of the jets rally around me if anyone interested in my service I can be reach at [email protected] or 404-263-7674 and I can send some pictures of the jets I build so far.
ID:	2191890   Click image for larger version
ID:	2191891   Click image for larger version
ID:	2191892   Click image for larger version
ID:	2191893   Click image for larger version
ID:	2191894   Click image for larger version
ID:	2191895   Click image for larger version
ID:	2191896   Click image for larger version
Old 12-09-2016, 09:05 PM
vquick
My Feedback: (71)
vquick's Avatar
Bump
Old 12-10-2016, 05:58 AM
sailing1
My Feedback: (134)
Saw this Comp Arf Viper at Mississippi Afterburner last year. The install was really good. The integration and functioning of the lighting system was spectacular both on the ground and in the air. From what I saw I sure wouldn't hesitate to give him a try if in the market for a new build!
Old 12-10-2016, 06:33 AM
vquick
My Feedback: (71)
vquick's Avatar
Thanks I still have that viper and now with a bigger turbine love the way that plane flight but will be for sale next year I want to build another little bigger and more detail and hope we see you againg in Mississippi Afterburner
Old 12-10-2016, 06:54 AM
vquick
My Feedback: (71)
vquick's Avatar
A friend of mine is Building a Big F-18 and ask me me to work on his Front tanks this plane have 2 tanks in the front and 2 saddle and is Twin but the 2 front tank are different size and he want to have 2 separate set of tank but same amount for each turbine so this is what i did
First I cut the top and the bottom of each particular tank after that i went and joint both tanks together after glue dry sand and seal that joint with 1 inch fiberglass tape and epoxy and let dry
ID:	2193000   Click image for larger version
ID:	2193001   Click image for larger version
Old 12-10-2016, 07:08 AM
vquick
My Feedback: (71)
vquick's Avatar
After dry I split the tanks in halve top to bottom and we decide to build a baffle for each side
ID:	2193005   Click image for larger version
ID:	2193010   Click image for larger version
ID:	2193011   Click image for larger version
Old 12-10-2016, 07:17 AM
vquick
My Feedback: (71)
vquick's Avatar
When I install the baffles also I add epoxy to the seam from the previous join cause when you cut Kevlar is not a clean cut so i seal all the Kevlar fiber then I build the wall to separate the 2 side from Kevlar and Fiberglass and is vacuum press and peel ply both sides also seal the old stoppers and install the new ones and vents.
ID:	2193015   Click image for larger version
ID:	2193016   Click image for larger version
ID:	2193017   Click image for larger version
ID:	2193018   Click image for larger version
ID:	2193020   Click image for larger version
Old 12-10-2016, 07:25 AM
vquick
My Feedback: (71)
vquick's Avatar
After dry the first side i grind all around to level and be ready for 2nd half so i glue my second have after dry i will sand all around and apply another 1 inch fiber glass tape with epoxy
ID:	2193034   Click image for larger version
Old 12-11-2016, 04:53 PM
vquick
My Feedback: (71)
vquick's Avatar
Tank is finish today I put the fiber glass tape around the seam with epoxy and let dry all I have left is install lines and clunk
ID:	2193172   Click image for larger version
ID:	2193173   Click image for larger version
ID:	2193174   Click image for larger version
Old 12-16-2016, 05:16 PM
vquick
My Feedback: (71)
vquick's Avatar
Default Jet Builder
More pictures of my builds
ID:	2193636   Click image for larger version
ID:	2193637   Click image for larger version
ID:	2193638   Click image for larger version
ID:	2193639   Click image for larger version
ID:	2193640   Click image for larger version
ID:	2193641   Click image for larger version
ID:	2193642   Click image for larger version
ID:	2193644   Click image for larger version
ID:	2193645   Click image for larger version
ID:	2193646   Click image for larger version
ID:	2193647   Click image for larger version
ID:	2193648   Click image for larger version
Old 12-18-2016, 08:59 AM
Shaun Evans
Shaun Evans's Avatar
Nice installs!
Old 12-18-2016, 09:29 AM
vquick
My Feedback: (71)
vquick's Avatar
Originally Posted by Shaun Evans
Nice installs!
Thanks Shaun
Old 12-20-2016, 06:09 PM
vquick
My Feedback: (71)
vquick's Avatar
few more pictures of another of my install
ID:	2193942   Click image for larger version
ID:	2193943   Click image for larger version
ID:	2193944   Click image for larger version
ID:	2193945   Click image for larger version
ID:	2193946   Click image for larger version
ID:	2193947   Click image for larger version
ID:	2193948   Click image for larger version
Old 12-20-2016, 06:12 PM
vquick
My Feedback: (71)
vquick's Avatar
more pictures
ID:	2193951   Click image for larger version
ID:	2193952   Click image for larger version
ID:	2193953   Click image for larger version
ID:	2193954   Click image for larger version
ID:	2193955   Click image for larger version
Old 12-22-2016, 08:12 PM
K.O.
Curious, what lighting system did you use on the Viper?
K.O.
Old 12-22-2016, 09:39 PM
vquick
My Feedback: (71)
vquick's Avatar
K.O.
Those are Unilight
Old 01-02-2017, 12:29 PM
vquick
My Feedback: (71)
vquick's Avatar
Few more pictures
ID:	2195278   Click image for larger version
ID:	2195279   Click image for larger version
ID:	2195280   Click image for larger version
ID:	2195281   Click image for larger version
ID:	2195282   Click image for larger version
Old 01-08-2017, 06:14 AM
vquick
My Feedback: (71)
vquick's Avatar
Some pictures of the Super Bandit I paint this last week all the markings are painted
ID:	2195971   Click image for larger version
ID:	2195972   Click image for larger version
ID:	2195973   Click image for larger version
ID:	2195974   Click image for larger version
ID:	2195975   Click image for larger version
ID:	2195976   Click image for larger version
ID:	2195977   Click image for larger version
Old 01-08-2017, 06:55 AM
CraigG
My Feedback: (40)
CraigG's Avatar
Victor,
How are you printing your heat shrink sleeves on the servo leads?
Thanks....Craig
Old 01-08-2017, 07:25 AM
vquick
My Feedback: (71)
vquick's Avatar
Originally Posted by CraigG
Victor,
Thanks....Craig
label machine DYMO they have a white shrink tubing
Old 01-08-2017, 07:57 AM
rbxbear44
My Feedback: (86)
Which size for wiring?
Old 01-08-2017, 10:14 AM
vquick
My Feedback: (71)
vquick's Avatar
9mm
Old 01-09-2017, 01:47 PM
CraigG
My Feedback: (40)
CraigG's Avatar
Thanks Victor.....the shrink tubing cartridges look a little expensive but they sure make a clean install versus the tabs most of us use.
Old 01-20-2017, 03:53 AM
YOADRIAN
YOADRIAN's Avatar
Hay Victor, i will dropping you a call later tonight, i have some vertical stabs that i want to have rebuild and have the linkages to the rudders moved to the outside and also a pair of horizontal stabs looking to rebuild for strength. Hope you deal with that type of mods. talk soon.
Old 01-20-2017, 03:48 PM
ravill
ravill's Avatar
Clean installs.
I cringe when I see festo's on THE most negative suction side. Its obvious that jet central uses it on their set ups and that many people do that right now with success but that little piece of tubing is subject to the most vacuum in the jet.
Great paint too! How much do you charge for paint like that?
