Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Scratch Built Kwik Fli III
Old 11-14-2017, 05:27 AM
  #51
erans
FlyerInOKC - I am not familiar with Calvin and Hobbs, but the drawings will look great on a Tiger.
As to my progress, I got the horizontal stabilizer sheeted. Using 1/32" (0.8mm) balsa, I had some "peeling damage" when removing the 3M blue tape from the sheeting joint. Nothing to worry about, some filler and sanding got it fixed.
Eran
Name:	2017_02_28 16 Kwik Fli 3 Horiz Stab.JPG
ID:	2245029   Click image for larger version
Name:	2017_02_28 17 Kwik Fli 3 Horiz Stab.JPG
ID:	2245030   Click image for larger version
Name:	2017_02_28 18 Kwik Fli 3 Horiz Stab.JPG
ID:	2245031   Click image for larger version
Name:	2017_03_01 01 Kwik Fli 3 Horiz Stab.JPG
ID:	2245032   Click image for larger version
Name:	2017_03_01 02 Kwik Fli 3 Horiz Stab.JPG
ID:	2245033   Click image for larger version
Name:	2017_03_02 01 Kwik Fli 3 Horiz Stab.JPG
ID:	2245034   Click image for larger version
Name:	2017_03_02 02 Kwik Fli 3 Horiz Stab.JPG
ID:	2245035   Click image for larger version
Name:	2017_03_02 03 Kwik Fli 3 Horiz Stab.JPG
Name:	2017_03_02 04 Kwik Fli 3 Horiz Stab.JPG
ID:	2245037   Click image for larger version
Name:	2017_03_02 05 Kwik Fli 3 Horiz Stab.JPG
ID:	2245038   Click image for larger version
Name:	2017_03_02 06 Kwik Fli 3 Horiz Stab.JPG
ID:	2245039   Click image for larger version
Name:	2017_03_03 01 Kwik Fli 3 Horiz Stab.JPG
ID:	2245040   Click image for larger version
Name:	2017_03_03 02 Kwik Fli 3 Horiz Stab.JPG
Old 11-14-2017, 06:08 AM
  #52
FlyerInOKC
FlyerInOKC's Avatar
0.8 mm Balsa skin that is thin. I'm so ham handed I don't think it would survive handling at my house.
Allow me to enlighten you, hopefully you can reach the site from Oz.
http://www.gocomics.com/calvinandhobbes/2017/11/14
Old 11-15-2017, 06:49 AM
  #53
erans
FlyerInOKC - Thank you for the link, it can be accessed from Oz : )
Elevator construction. I managed to pick up an error on my drawing prior to cutting, so saved myself re-doing it... A fiddly sanding work to fit the tube joiner.
Eran
Name:	2017_03_06 01 Kwik Fli 3 Ele.JPG
ID:	2245158   Click image for larger version
Name:	2017_03_06 02 Kwik Fli 3 Ele.JPG
ID:	2245159   Click image for larger version
Name:	2017_03_06 03 Kwik Fli 3 Ele.JPG
ID:	2245160   Click image for larger version
Name:	2017_03_06 04 Kwik Fli 3 Ele.JPG
ID:	2245161   Click image for larger version
Name:	2017_03_06 05 Kwik Fli 3 Ele.JPG
ID:	2245162   Click image for larger version
Name:	2017_03_06 06 Kwik Fli 3 Ele.JPG
ID:	2245163   Click image for larger version
Name:	2017_03_06 07 Kwik Fli 3 Ele.JPG
ID:	2245164   Click image for larger version
Name:	2017_03_06 08 Kwik Fli 3 Ele.JPG
Name:	2017_03_06 09 Kwik Fli 3 Ele.JPG
ID:	2245166   Click image for larger version
Name:	2017_03_07 01 Kwik Fli 3 Ele.JPG
ID:	2245167   Click image for larger version
Name:	2017_03_07 02 Kwik Fli 3 Ele.JPG
ID:	2245168   Click image for larger version
Name:	2017_03_07 03 Kwik Fli 3 Ele.JPG
Old 11-16-2017, 06:03 AM
  #54
erans
Covering therapy...
Eran
Name:	2017_03_07 04 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245232   Click image for larger version
Name:	2017_03_07 05 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245233   Click image for larger version
Name:	2017_03_07 06 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245234   Click image for larger version
Name:	2017_03_07 07 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245235   Click image for larger version
Name:	2017_03_07 08 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245236   Click image for larger version
Name:	2017_03_07 09 Kwik Fli 3 Horiz Stab Covering.JPG
ID:	2245237   Click image for larger version
Name:	2017_03_07 10 Kwik Fli 3 Ele Covering.JPG
ID:	2245238   Click image for larger version
Name:	2017_03_07 11 Kwik Fli 3 Ele Covering.JPG
Name:	2017_03_07 12 Kwik Fli 3 Ele Covering.JPG
ID:	2245241   Click image for larger version
Name:	2017_03_07 13 Kwik Fli 3 Ele Covering.JPG
ID:	2245242   Click image for larger version
Name:	2017_03_07 14 Kwik Fli 3 Ele Covering.JPG
Old 11-16-2017, 06:48 AM
  #55
FlyerInOKC
FlyerInOKC's Avatar
Nice job!
Old 11-17-2017, 05:25 AM
  #56
erans
FlyerInOKC - Thank you.
I completed the covering of the stab and elevator. Next is to complete the wing covering.
Eran
Name:	2017_03_09 01 Kwik Fli 3 Ele Covering.JPG
ID:	2245333   Click image for larger version
Name:	2017_03_09 02 Kwik Fli 3 Ele Covering.JPG
ID:	2245334   Click image for larger version
Name:	2017_03_09 03 Kwik Fli 3 Ele Covering.JPG
ID:	2245335   Click image for larger version
Name:	2017_03_09 04 Kwik Fli 3 Ele Covering.JPG
ID:	2245336   Click image for larger version
Name:	2017_03_09 05 Kwik Fli 3 Ele Covering.JPG
ID:	2245337   Click image for larger version
Name:	2017_03_09 06 Kwik Fli 3 Ele Covering.JPG
ID:	2245338   Click image for larger version
Name:	2017_03_09 07 Kwik Fli 3 Ele Covering.JPG
Old 11-17-2017, 07:26 AM
  #57
FlyerInOKC
FlyerInOKC's Avatar
You are making good headway!
Old 11-18-2017, 11:30 PM
  #58
erans
FlyerInOKC - When compared with the 1/5th scale Messerschmitt BF-109 project from a couple of years back which consumed 5 years of my time, this one is a walk in the park...
I got the top side of the wing covered.
Eran.
Name:	2017_04_13 01 Kwik Fli 3 Wing Covering.JPG
ID:	2245568   Click image for larger version
Name:	2017_04_13 02 Kwik Fli 3 Wing Covering.JPG
ID:	2245569   Click image for larger version
Name:	2017_04_13 03 Kwik Fli 3 Wing Covering.JPG
ID:	2245570   Click image for larger version
Name:	2017_04_13 04 Kwik Fli 3 Wing Covering.JPG
ID:	2245571   Click image for larger version
Name:	2017_04_25 01 Kwik Fli 3 Wing Covering.JPG
ID:	2245572   Click image for larger version
Name:	2017_04_25 02 Kwik Fli 3 Wing Covering.JPG
ID:	2245573   Click image for larger version
Name:	2017_04_25 03 Kwik Fli 3 Wing Covering.JPG
Old 11-22-2017, 05:00 AM
  #59
erans
I made a start on the fuselage, cutting formers and doublers. I also glued the firewall two plywood half the thickness pieces.
Eran
Name:	2017_05_09 01 Kwik Fli 3 formers.JPG
ID:	2245931   Click image for larger version
Name:	2017_05_11 01 Kwik Fli 3 Fus Doublers.JPG
ID:	2245932   Click image for larger version
Name:	2017_05_11 02 Kwik Fli 3 Fus Doublers.JPG
ID:	2245933   Click image for larger version
Name:	2017_05_11 03 Kwik Fli 3 Fus Doublers.JPG
ID:	2245934   Click image for larger version
Name:	2017_05_11 04 Kwik Fli 3 Fus Doublers.JPG
ID:	2245935   Click image for larger version
Name:	2017_05_11 05 Kwik Fli 3 Fus Doublers.JPG
ID:	2245936   Click image for larger version
Name:	2017_05_11 06 Kwik Fli 3 Firewall.JPG
Old 11-22-2017, 05:52 AM
  #60
FlyerInOKC
FlyerInOKC's Avatar
The fuselage will be taking form quite soon I see. I see you use the same method for cutting out formers I do when scratch building or building from plans.
Old 11-23-2017, 04:40 AM
  #61
erans
FlyerInOKC - I think I got the idea of the spray contact adhesive here in the forums few years ago. It works great.
I cut a "kit" of fuselage parts... I traced the plans for the fuselage side view to keep the plans for the build.
Eran
Name:	2017_05_015 01 Kwik Fli 3 Fus.JPG
ID:	2246044   Click image for larger version
Name:	2017_05_015 02 Kwik Fli 3 Fus.JPG
ID:	2246045   Click image for larger version
Name:	2017_05_015 03 Kwik Fli 3 Fus.JPG
ID:	2246046   Click image for larger version
Name:	2017_05_015 04 Kwik Fli 3 Fus.JPG
ID:	2246047   Click image for larger version
Name:	2017_05_015 05 Kwik Fli 3 Fus.JPG
ID:	2246048   Click image for larger version
Name:	2017_05_015 06 Kwik Fli 3 Fus.JPG
ID:	2246049   Click image for larger version
Name:	2017_05_015 07 Kwik Fli 3 Fus.JPG
ID:	2246050   Click image for larger version
Name:	2017_05_015 08 Kwik Fli 3 Fus.JPG
Name:	2017_05_015 09 Kwik Fli 3 Fus.JPG
ID:	2246052   Click image for larger version
Name:	2017_05_015 10 Kwik Fli 3 Fus.JPG
ID:	2246053   Click image for larger version
Name:	2017_05_015 11 Kwik Fli 3 Fus.JPG
ID:	2246054   Click image for larger version
Name:	2017_05_015 12 Kwik Fli 3 Fus.JPG
ID:	2246055   Click image for larger version
Name:	2017_05_015 13 Kwik Fli 3 Fus.JPG
Old 11-23-2017, 07:18 AM
  #62
FlyerInOKC
FlyerInOKC's Avatar
I have started taking the plans to Office Depot or Staples and having a quick copy made to cut to pieces. The cost isn't bad at all.
Old 11-26-2017, 10:11 PM
  #63
erans
Plywood doublers glued to the fuselage sides and the tail pieces glued together.
Eran
Name:	2017_05_16 01 Kwik Fli 3 Fus.JPG
ID:	2246268   Click image for larger version
Name:	2017_05_16 02 Kwik Fli 3 Fus.JPG
ID:	2246269   Click image for larger version
Name:	2017_05_16 03 Kwik Fli 3 Fus.JPG
Old 11-27-2017, 06:02 AM
  #64
FlyerInOKC
FlyerInOKC's Avatar
Eran, you are making good progress!
Old 11-28-2017, 12:15 AM
  #65
erans
FlyerInOKC - Progress is OK for the time spent : )
Some more work on the fuselage. The drawing of the top section was not symmetric (pre-CAD days), so I cut it on the centre line and mirrored it while tracing to the wood.
Eran
Name:	2017_06_14 02 Kwik Fli 3 Fus Incorrect Build.JPG
ID:	2246411   Click image for larger version
Name:	2017_06_19 01 Kwik Fli 3 Fus.JPG
ID:	2246412   Click image for larger version
Name:	2017_06_19 02 Kwik Fli 3 Fus.JPG
ID:	2246413   Click image for larger version
Name:	2017_06_19 03 Kwik Fli 3 Fus.JPG
ID:	2246414   Click image for larger version
Name:	2017_06_19 04 Kwik Fli 3 Fus.JPG
ID:	2246415   Click image for larger version
Name:	2017_06_19 05 Kwik Fli 3 Fus.JPG
ID:	2246416   Click image for larger version
Name:	2017_06_19 06 Kwik Fli 3 Fus.JPG
ID:	2246417   Click image for larger version
Name:	2017_06_19 07 Kwik Fli 3 Fus.JPG
Name:	2017_06_19 08 Kwik Fli 3 Fus.JPG
Old 11-28-2017, 07:14 AM
  #66
FlyerInOKC
FlyerInOKC's Avatar
I had some plans cut a few years back and one thing the cutter did was fold the drawing over in CAD and then pick the best outline to use for both sides. I was surprised because by eye the drawing halves looked perfect.
Old 11-30-2017, 10:02 PM
  #67
erans
Some work on the fuselage, gluing the triangles to the top piece.
Eran
Name:	2017_06_20 01 Kwik Fli 3 Fus.JPG
ID:	2246608   Click image for larger version
Name:	2017_06_20 02 Kwik Fli 3 Fus.JPG
ID:	2246609   Click image for larger version
Name:	2017_06_20 03 Kwik Fli 3 Fus.JPG
ID:	2246610   Click image for larger version
Name:	2017_06_20 04 Kwik Fli 3 Fus.JPG
ID:	2246611   Click image for larger version
Name:	2017_06_20 05 Kwik Fli 3 Fus.JPG
ID:	2246612   Click image for larger version
Name:	2017_06_20 06 Kwik Fli 3 Fus.JPG
Old 12-01-2017, 06:53 AM
  #68
FlyerInOKC
FlyerInOKC's Avatar
It looks like you got a good start on the fuselage.
Old 12-02-2017, 04:26 AM
  #69
erans
FlyerInOKC - I prefer building wings then fuselages... This is why it is always going slower for me.
As can be seen managed to cut the formers too wide, so I had to trim them all...
Eran
Name:	2017_06_21 01 Kwik Fli 3 Fus.JPG
ID:	2246670   Click image for larger version
Name:	2017_06_22 01 Kwik Fli 3 Fus.JPG
ID:	2246671   Click image for larger version
Name:	2017_06_22 02 Kwik Fli 3 Fus.JPG
ID:	2246672   Click image for larger version
Name:	2017_06_22 03 Kwik Fli 3 Fus.JPG
ID:	2246673   Click image for larger version
Name:	2017_06_22 04 Kwik Fli 3 Fus.JPG
ID:	2246674   Click image for larger version
Name:	2017_06_22 05 Kwik Fli 3 Fus.JPG
ID:	2246675   Click image for larger version
Name:	2017_06_23 06 Kwik Fli 3 Fus Formers wide fix.JPG
ID:	2246676   Click image for larger version
Name:	2017_06_23 07 Kwik Fli 3 Fus Formers wide fix.JPG
Name:	2017_06_23 08 Kwik Fli 3 Fus Formers wide fix.JPG
Old 12-04-2017, 03:22 AM
  #70
erans
Fixing another mistake I did with the fuselage sides... I didn't cut them to the correct line...
Eran
Name:	2017_06_23 09 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246807   Click image for larger version
Name:	2017_06_23 10 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246808   Click image for larger version
Name:	2017_06_23 11 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246809   Click image for larger version
Name:	2017_06_23 12 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246810   Click image for larger version
Name:	2017_06_23 13 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246811   Click image for larger version
Name:	2017_06_23 14 Kwik Fli 3 Fus sides error fix.JPG
ID:	2246812   Click image for larger version
Name:	2017_06_23 15 Kwik Fli 3 Fus sides error fix.JPG
Old 12-04-2017, 06:59 AM
  #71
FlyerInOKC
FlyerInOKC's Avatar
Hiding your mistakes, the test of a true builder!
Old 12-05-2017, 03:49 AM
  #72
erans
FlyerInOKC - I am yet to know a builder that do not make mistakes during a scratch build project. Some will never post the fact that they made a mistake, but I have no issue with it
I glued the fuselage sides one at a time and then glued the firewall into place.
Eran
Name:	2017_06_25 02 Kwik Fli 3 Fus.JPG
ID:	2246974   Click image for larger version
Name:	2017_06_25 04 Kwik Fli 3 Fus.JPG
ID:	2246975   Click image for larger version
Name:	2017_06_26 01 Kwik Fli 3 Fus.JPG
ID:	2246976   Click image for larger version
Name:	2017_06_26 02 Kwik Fli 3 Fus.JPG
ID:	2246977   Click image for larger version
Name:	2017_06_26 03 Kwik Fli 3 Fus.JPG
ID:	2246978   Click image for larger version
Name:	2017_06_26 04 Kwik Fli 3 Fus.JPG
ID:	2246979   Click image for larger version
Name:	2017_06_26 06 Kwik Fli 3 Fus Firewall.JPG
ID:	2246980   Click image for larger version
Name:	2017_06_26 07 Kwik Fli 3 Fus Firewall.JPG
Name:	2017_06_26 08 Kwik Fli 3 Fus Firewall.JPG
Old 12-05-2017, 05:55 AM
  #73
FlyerInOKC
FlyerInOKC's Avatar
Its really starting to take shape.
Old 12-06-2017, 03:33 AM
  #74
erans
The bottom of the fuselage cut and glued into place,
Eran
Name:	2017_06_27 01 Kwik Fli 3 Fus.JPG
ID:	2247049   Click image for larger version
Name:	2017_06_27 02 Kwik Fli 3 Fus.JPG
ID:	2247050   Click image for larger version
Name:	2017_06_27 03 Kwik Fli 3 Fus.JPG
ID:	2247051   Click image for larger version
Name:	2017_06_27 04 Kwik Fli 3 Fus.JPG
ID:	2247052   Click image for larger version
Name:	2017_06_27 05 Kwik Fli 3 Fus.JPG
ID:	2247053   Click image for larger version
Name:	2017_06_27 06 Kwik Fli 3 Fus.JPG
ID:	2247054   Click image for larger version
Name:	2017_06_27 07 Kwik Fli 3 Fus.JPG
ID:	2247055   Click image for larger version
Name:	2017_06_27 08 Kwik Fli 3 Fus.JPG
Old 12-06-2017, 06:53 AM
  #75
FlyerInOKC
FlyerInOKC's Avatar
Moving right along!
