Reload this Page >
CY MODELS La-7//Evolution 160 radial
Old 07-24-2017, 08:33 AM
  #51
n8622t
My Feedback: (8)
Ready for primer
Old 07-24-2017, 09:32 PM
  #52
warbird04
Jimmy,
You got a incredible job, well done. Do you have brocken in the Evolution radial motor?
My canopy opening system is fonctionnal, and simple to make. The closing way is made with magnets. I can post you new pictures about the slidding system, but you must wait 14 days, i am curently in holidays...
Here another pictures on my La-7 progress:
ID:	2225496   Click image for larger version
ID:	2225497   Click image for larger version
ID:	2225498   Click image for larger version
ID:	2225499   Click image for larger version
Old 07-25-2017, 05:08 AM
  #53
n8622t
My Feedback: (8)
Enjoy that holiday warbird and Thanks for the nice comments. I look forward to seeing how you did your canopy. It looks great!!
Old 07-26-2017, 04:58 PM
  #54
n8622t
My Feedback: (8)
Tailwheel is finished...
ID:	2225705   Click image for larger version
Old 07-26-2017, 05:00 PM
  #55
n8622t
My Feedback: (8)
Now back to the wing
Old 07-28-2017, 10:25 AM
  #56
n8622t
My Feedback: (8)
While setting th toe in I discovered the OEM struts weren't good enough quality so I ordered a set from Robart....so I'll set the wing aside and work on the business end of the fuse
ID:	2225978   Click image for larger version
ID:	2225979   Click image for larger version
Old 07-28-2017, 10:31 AM
  #57
n8622t
My Feedback: (8)
So I've measured the engine opening of the cowl and it's not quite scale so I'll open it up an additional 1 1/2"
ID:	2225981   Click image for larger version
Old 07-28-2017, 10:33 AM
  #58
n8622t
My Feedback: (8)
Make a tool to mark it
ID:	2225983   Click image for larger version
ID:	2225984   Click image for larger version
Old 07-28-2017, 10:35 AM
  #59
n8622t
My Feedback: (8)
Now for the fun...cutting it round!!
ID:	2225986   Click image for larger version
Old 07-28-2017, 11:34 AM
  #60
n8622t
My Feedback: (8)
Rough cut....should I take a little more??
ID:	2225988   Click image for larger version
ID:	2225989   Click image for larger version
ID:	2225990   Click image for larger version
Old 07-29-2017, 12:18 PM
  #61
n8622t
My Feedback: (8)
Just came in the mail from Iflytailies
ID:	2226129   Click image for larger version
ID:	2226130   Click image for larger version
Old 07-30-2017, 06:51 AM
  #62
n8622t
My Feedback: (8)
Smooth out the cut
Old 07-30-2017, 06:53 AM
  #63
n8622t
My Feedback: (8)
Then make a piece of wood round
Old 07-30-2017, 07:38 AM
  #64
n8622t
My Feedback: (8)
Add a second ring for strength
Old 07-30-2017, 07:39 AM
  #65
n8622t
My Feedback: (8)
Ready for sanding
Old 07-30-2017, 02:39 PM
  #66
n8622t
My Feedback: (8)
Ready for a coat of resin
Old 07-30-2017, 04:25 PM
  #67
n8622t
My Feedback: (8)
Firewall is drilled!!!
Old 07-31-2017, 05:09 PM
  #68
n8622t
My Feedback: (8)
More tedious work to do
Old 07-31-2017, 05:13 PM
  #69
n8622t
My Feedback: (8)
Everything is epoxy coated so I'll call it a day and get the cowl drilled and engine mounted tomorrow
ID:	2226404   Click image for larger version
ID:	2226405   Click image for larger version
Old 08-01-2017, 06:13 PM
  #70
n8622t
My Feedback: (8)
Had to make the engine mounting bolts
ID:	2226512   Click image for larger version
ID:	2226513   Click image for larger version
Old 08-01-2017, 06:22 PM
  #71
n8622t
My Feedback: (8)
Cowl is mounted
ID:	2226519   Click image for larger version
Old 08-01-2017, 06:25 PM
  #72
n8622t
My Feedback: (8)
Got it mounted
Old 08-01-2017, 06:27 PM
  #73
n8622t
My Feedback: (8)
Working on cowl detail next
ID:	2226522   Click image for larger version
Old 08-02-2017, 12:32 AM
  #74
warbird04
Take special care to the hot exhaust cooling air! It is a big problem with the La-7, there are nothing to make escape hot air from the coling... and the 2 openig for the side exhaust are not enought...
Can anybody explain how the full size La-7 motor cooling work?
Old 08-02-2017, 08:58 AM
  #75
n8622t
My Feedback: (8)
That's a good point Warbird....I plan on opening the bottom of the cowl to allow the hot air to move away from the engine. I'll post a pic for you when I get back into the shop.
Hows your build going? Are you still on holiday?
