Reload this Page >
CY MODELS La-7//Evolution 160 radial
Old 10-20-2017, 06:50 AM
  #326
n8622t
My Feedback: (8)
Got the inner doors back on👍
Old 10-20-2017, 09:00 AM
  #327
n8622t
My Feedback: (8)
Originally Posted by warbird04
Hello Jimmy,
You make an incredible job on the La-7... continue so! The result is perfect, and i Wonder to see the maiden.
After balance and final assembly, give me please your final weight.
For me, the Lavotchkin will be ready this afternoon. I send you some details pictures about the result this week-end. The maiden will go next week, this time we have some rainy day...
In the german forum about the Cy Model La-7, i find an info about the deflection about the control surface:
- for elevators, +/- 6 cm at largest point.
- for ailerons +4.5 cm / -3.5 cm at point near the flaps.
- 25-35 % expo on elevator and aileron
- CG is confirmed at 195mm measured on fuselage side (as discussed previously)
See you soon.
warbird those measurements on the elevator and aileron travels are really small compared to what I have programmed.....I need to go back into my radio and reduce the travel I have set up. Thanks for that info, that should help my maiden flight
Old 10-20-2017, 11:41 AM
  #328
n8622t
My Feedback: (8)
Just picked up my paint masks
ID:	2241705   Click image for larger version
Old 10-20-2017, 12:26 PM
  #329
n8622t
My Feedback: (8)
Checked the cowl rocker arm clearances....all good 👍Engine comes back off to finish painting😜
Old 10-20-2017, 12:29 PM
  #330
n8622t
My Feedback: (8)
I can't wait to start this thing😃
Old 10-21-2017, 09:04 AM
  #331
n8622t
My Feedback: (8)
Hours of prep for a few minutes of painting😜
ID:	2241834   Click image for larger version
ID:	2241835   Click image for larger version
Old 10-21-2017, 10:41 AM
  #332
n8622t
My Feedback: (8)
One on
Old 10-21-2017, 01:08 PM
  #333
n8622t
My Feedback: (8)
Now for the cure time then on to the stars👍
ID:	2241874   Click image for larger version
ID:	2241878   Click image for larger version
ID:	2241879   Click image for larger version
Old 10-21-2017, 01:56 PM
  #334
n8622t
My Feedback: (8)
Once the stars are on I'll be able to finish it
ID:	2241917   Click image for larger version
ID:	2241918   Click image for larger version
Old 10-21-2017, 09:09 PM
  #335
BobH
Looking so good.. you close now )
Old 10-22-2017, 05:00 AM
  #336
n8622t
My Feedback: (8)
Thanks BobH😃 Gonna work on my trailer bunk today so it can ride to the Dino DiGiorgio Memorial Flyin the first of November...the stars should arrive tomorrow so I can finish the paint work
Old 10-22-2017, 12:11 PM
  #337
warbird04
Some news about my Lavotchkin. I made the first tuning on the Saito FG-84 R3. You can see this on youtube..
Take a look on my others videos, all named Warbird04 (search with this name).
I post you later some more pictures and coments.
Old 10-22-2017, 12:37 PM
  #338
n8622t
My Feedback: (8)
https://www.youtube.com/watch?v=A4Hl7GoUL6Y
Sweeeeeeet!!!! I like your remote rpm console warbird. Hope you get some good weather soon for tte maiden, I'll be looking for the video👍😃
Old 10-22-2017, 04:01 PM
  #339
n8622t
My Feedback: (8)
Cradle cut and ready to roll 😃
ID:	2242053   Click image for larger version
ID:	2242054   Click image for larger version
Old 10-22-2017, 04:19 PM
  #340
BobH
Good luck at Dino's. I was thinking about attending but this year I probably wont make it.
Old 10-22-2017, 08:27 PM
  #341
warbird04
For CG balance, i use this method.
Old 10-22-2017, 08:37 PM
  #342
warbird04
As discussed, here you find some detailled pictures about my Lavotchkin.
ID:	2242136   Click image for larger version
ID:	2242137   Click image for larger version
ID:	2242138   Click image for larger version
ID:	2242139   Click image for larger version
ID:	2242140   Click image for larger version
ID:	2242141   Click image for larger version
ID:	2242142   Click image for larger version
ID:	2242144   Click image for larger version
Old 10-23-2017, 04:10 AM
  #343
n8622t
My Feedback: (8)
Thanks BobH....this may be the last year Dino has his event at this field. According to Rex, the GMA has been fighting over the last three years to keep their field. We all hate to see them lose it because they have so much invested to make it the great place that it is. Anyway it's my 4th year to go and it's a great event. I'm sure you would keep it on your calendar if you can make it 😃👍
Old 10-23-2017, 04:21 AM
  #344
n8622t
My Feedback: (8)
Awesome warbird!! You look ready to go....how much does your La-7 weigh? I'm hoping to get mine weighed by Wednesday when I balance it. My timeline all hinges on the arrival of my star paint masks. Looking forward to you maiden warbird 👍
Old 10-23-2017, 04:29 AM
  #345
n8622t
My Feedback: (8)
I was watching you video again...that Saito sounds awesome. Did you do anything special for the initial breakin?
Old 10-23-2017, 08:00 AM
  #346
n8622t
My Feedback: (8)
Now just cut the hole where the mask will go
ID:	2242191   Click image for larger version
ID:	2242192   Click image for larger version
Old 10-23-2017, 10:25 AM
  #347
warbird04
Jimmy,
My Lavotchkin final weight is 15.4kg, dry, without pilot and cockpit. I add for the maiden 250gr lead on the motor mount, this for safety, but after i will remove the lead.
My Saito is already broken in, i have make this last year after many intake modification that i have self engineered. My Saito swing a Mejzlik 24x12 2 blades at 6200 rpm/min.
If weather is good on freiday afternoon, i maiden it.
Will see, stay online.
You do an great job on your Lavotchkin, I can not wait to see your final weight, final setup, and the maiden!
Old 10-23-2017, 01:10 PM
  #348
n8622t
My Feedback: (8)
Jimmy,
your plane is a winner warbird ....at that weight it is going to be a joy to fly👍👍
i just had a set back, my masks arrived today for the final paint and they all had flaws , oh well free stuff isn't always a good deal
ID:	2242250   Click image for larger version
Old 10-23-2017, 01:11 PM
  #349
n8622t
My Feedback: (8)
They all had notches cut out of them
Old 10-25-2017, 08:38 AM
  #350
n8622t
My Feedback: (8)
It'll be difficult for me to paint over this prop....
ID:	2242368   Click image for larger version
