Reload this Page >
CY MODELS La-7//Evolution 160 radial
Old 10-03-2017, 08:05 AM
  #251
n8622t
My Feedback: (8)
Top is drilled!! 😃
ID:	2234961   Click image for larger version
Old 10-03-2017, 09:53 AM
  #252
n8622t
My Feedback: (8)
Access panels cut and drilled
ID:	2234971   Click image for larger version
Old 10-03-2017, 09:54 AM
  #253
n8622t
My Feedback: (8)
Now to wet sand it all😜
Old 10-03-2017, 10:28 AM
  #254
n8622t
My Feedback: (8)
Sanded and washed....
Old 10-03-2017, 10:30 AM
  #255
n8622t
My Feedback: (8)
Now for the final sanding of the wings and fuse👍👍
Old 10-03-2017, 01:47 PM
  #256
n8622t
My Feedback: (8)
Ok I got the wings sanded and I'm worn out....pick it back up tomorrow 😃 This part gets the sanding treatment tomorrow ...
Old 10-04-2017, 09:01 AM
  #257
n8622t
My Feedback: (8)
Wings sanded and hinges glued in....time for glueing in horns
ID:	2239985   Click image for larger version
Old 10-04-2017, 11:24 AM
  #258
n8622t
My Feedback: (8)
Let these cure
Old 10-04-2017, 11:26 AM
  #259
n8622t
My Feedback: (8)
Now for some sheet metal😃
Old 10-04-2017, 01:59 PM
  #260
n8622t
My Feedback: (8)
One ready for paint 👍
ID:	2240015   Click image for larger version
ID:	2240016   Click image for larger version
Old 10-04-2017, 07:14 PM
  #261
BobH
Looks really good Jimmy!
Old 10-05-2017, 10:28 AM
  #262
n8622t
My Feedback: (8)
Two wings ready for paint
Old 10-05-2017, 01:52 PM
  #263
n8622t
My Feedback: (8)
thanks Bob....fuse is going under the sandpaper tomorrow. I Had to fill the rudder cable exits and sand them before the fuse gets sanded��
Old 10-05-2017, 01:59 PM
  #264
n8622t
My Feedback: (8)
I'll get these servos in and programmed this evening then call it a day
Old 10-06-2017, 09:06 AM
  #265
n8622t
My Feedback: (8)
Got the stab tube drilled👍
Old 10-06-2017, 10:37 AM
  #266
n8622t
My Feedback: (8)
Ready to start sanding👍
ID:	2240175   Click image for larger version
Old 10-06-2017, 02:44 PM
  #267
n8622t
My Feedback: (8)
Add the hearts, red nose, guns, and sheet metal bands then cowl is finished
ID:	2240188   Click image for larger version
ID:	2240189   Click image for larger version
ID:	2240190   Click image for larger version
Old 10-06-2017, 09:18 PM
  #268
warbird04
Yes Jimmy, it make's good so... Superb cowling!
I give you news about my construction next time. This day we have an meeting with some friends.
Old 10-07-2017, 01:49 AM
  #269
n8622t
My Feedback: (8)
Good to see you in here warbird.... yes I'd like to see how your work is coming along. I have duties with the wife today so I'm not sure if I'll get to the fuse, she might let me play this afternoon 😃
Old 10-08-2017, 10:13 AM
  #270
n8622t
My Feedback: (8)
Cutting the last of the sheet metal
Old 10-08-2017, 11:14 AM
  #271
n8622t
My Feedback: (8)
Now just glue it on👍
Old 10-08-2017, 01:14 PM
  #272
n8622t
My Feedback: (8)
Glue is laid up....
Old 10-08-2017, 01:20 PM
  #273
n8622t
My Feedback: (8)
That was a real pain in the A##!!!😜
Old 10-08-2017, 08:28 PM
  #274
warbird04
For me the Lavotchkine comes in final assembly.
I adjusted the wheel geometry for ensure that it roll straight.
All control surface are mounted, and make removable. I replace the pin in each hinges with a long piano wire (1.5mm). For ailerons, it's necessary to ad some plastic tube into the aileron to guide wire. For this, I dug a throat into the aileron, and glued a plastic tube, an refill with some époxy and microballons. Sorry, no pictures about this... but pictures from other control surface.
Tonight, I going forward with Saito FG-84 R3 final assembly.
ID:	2240627   Click image for larger version
ID:	2240628   Click image for larger version
ID:	2240629   Click image for larger version
ID:	2240630   Click image for larger version
Old 10-09-2017, 04:07 AM
  #275
n8622t
My Feedback: (8)
very nice work warbird !!! Have you ran the Saito or is it still brand new? If it is brand new I have some recommendations on a break in procedure a friend of mine used I would be happy to share with you if you are interested .....let me know. Good job on the La😃😃
