Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 03-26-2016, 03:55 AM
  #376
vatechguy3
Originally Posted by Lifer
Mine needed 2.2 pounds of ballast to achieve it's balance point. I used a heavier engine and moved everything I could to the front. Canopy was glued on 2 days ago and decals are starting to go on. Getting close. Should be able top test-run the engine next week.
Worried about this myself.
I have a da50 for power, was considering selling it and going wiith an eme70 twin.
Would rather have more engine weight than lead.
How is your ground clearance with the 24x10 2 blade?
Tony
Old 03-26-2016, 04:28 AM
  #377
vatechguy3
When drilling out the tailwheel for a 3/16 axle of the robart retract, how are you guys keeping the wheel centered?
Using bushings on both sides?
Tony
Old 03-26-2016, 04:32 AM
  #378
Lifer
Lifer's Avatar
Plenty of clearance with the 24x10x2.
Don't know how the twin would fit. The EME 60 sticks out a bit, but being on the bottom, it isn't very noticeable.
Test flight will be delayed for about 20-30 days. Getting the cataract removed from the left eye on Tuesday. Did the right eye 3 weeks ago. In that eye, I have the vision of a teenager now. Not bad for a 60 year-old geezer!
Old 11-12-2016, 08:55 PM
  #379
tailskid
My Feedback: (34)
tailskid's Avatar
Were you guys satisfied with the ARF's technique for securing the cowl?
Jerry
Old 11-13-2016, 07:53 AM
  #380
SWORDSN
My Feedback: (13)
It works fine,but it was difficult for me to tack glue the ply ring in the right place,but I finally got it right,
Old 11-13-2016, 08:39 AM
  #381
Lifer
Lifer's Avatar
Same here. I had to re-position the cowl ring after the first attempt. Needed to break the glue around it but luckily no damaged was incurred.
Old 11-15-2016, 02:41 PM
  #382
tailskid
My Feedback: (34)
tailskid's Avatar
I just glued in the blocks...from what you guys are saying, I probably did it wrong....when will I find that out???
Old 11-15-2016, 07:51 PM
  #383
BobH
Doesn't look like you'll encounter any problems. Your muffler is out of the way. That can be an issue if you have a radial engine..
Old 11-15-2016, 07:52 PM
  #384
tailskid
My Feedback: (34)
tailskid's Avatar
Did you guys stick with the supplied fuel tank or replace it? I'm thinking of putting in a Du-Bro one....thoughts????
Jerry
Old 11-15-2016, 07:57 PM
  #385
JeffH
My Feedback: (43)
Ditch the stock tank. My dad's just split at the neck after about a season of use.
Old 11-15-2016, 08:01 PM
  #386
tailskid
My Feedback: (34)
tailskid's Avatar
I've heard rumors to that effect.....thanks for the input.
Old 11-15-2016, 08:13 PM
  #387
BobH
I replaced the supplied tank with a clear, pre-plumed tank.
Was simple to do.
Old 11-16-2016, 10:40 PM
  #388
Chris Nicastro
Chris Nicastro's Avatar
My stock tank leaked, ditch it. I went with a Sullivan tank and alloy tank cap upgrade set.
I redesigned the cowl mount so it had external screws. The stock set up had issues coming loose on my plane. Afterwards it was fine, no issues with the cowl for about 50 flights.
I used a DLE 55RA and Xoar 22x10 prop. Very clean install. I did have to add quite a bit of ballast even after moving my larger than necessary ignition battery pack up front.
Old 11-17-2016, 09:31 AM
  #389
vatechguy3
Has anyone come up with an onboard starting unit for a da50?
Would be nice to use instead of lead.
Tony
Old 11-17-2016, 11:23 AM
  #390
ForcesR
Tony
Apparently the EME electric starter can be fitted to the DA50. The link below identifies that the EME electric starter can be fitted, see last sentence under "Specifications".
Roger
https://www.rcpro.no/detaljer/EME55S...0cc-gas-engine
Old 11-19-2016, 04:03 PM
  #391
vatechguy3
Maidened mine today.
First flight was uneventful, except for some loose covering, which i applied as part of a scheme change. A little tape, and went up for flight 2.
Major horizontal stab / elevator flutter on a semi fast pass. Throttled down and landed quick. On roll out, hit a bump and the landing gear fell apart. There was no flat ground on the oleo strut set screws. Packed up and came home.
So looks like i need to upgrade the elevator linkages. I am thinking 5/32 carbon rod with 4-40 end links. Anyone know where to find a sheath for this size?
Or other options for upgrading / stiffening the linkages?
Tony
Old 11-19-2016, 04:58 PM
  #392
tailskid
My Feedback: (34)
tailskid's Avatar
Any cooling issues? Did you use the scale engine?
Old 11-19-2016, 06:40 PM
  #393
Chris Nicastro
Good save!
So check that the stab assembly screws and epoxy for the stab is still intact.
You can use the stock rods but slip on brass tubes and solder the unsupported length from the bulkhead to the bell rank.
The brass tube can go up to the threads on the rod.
Ive done this before on the Corsair and it works fine.
Also so look at the gap between the stab and elevators to be sure it's as tight as possible. An air gap here can cause flutter. You can fold in and iron some covering strips to seal the gaps. Even packing tape can work. Otherwise you have to reset the hinges.
Post pics!!
Old 11-20-2016, 12:47 PM
  #394
vatechguy3
Will get some pics.
I thought the hinge gap was fine, but will double check and seal just to be safe.
Have to recover the one wing panel, more covering ripped off, oh well.
As for the brass tube, do you think that is better than upgrading to carbon rods?
It does look like there is some flex in the pushrod housing too. Oh how i miss the direct connection like on my aerobatic planes. Do not want to put servos in the tail, would have to add even more lead.
Old 11-20-2016, 02:24 PM
  #395
tailskid
My Feedback: (34)
tailskid's Avatar
Has anyone put a hatch on the top of the fuse so the switches, fuel, etc can be accessed easily? I'm thinking about it....
Old 11-20-2016, 03:33 PM
  #396
Chris Nicastro
Will get some pics.
Well part of the issue is in the flex of the Torque Rod built into the elevators. It's crap soft wire. So to do it right you'd need to tear into that and replace them with good piano wire.
Full length carbon rods would be great too.
Old 11-27-2016, 08:45 AM
  #397
COL J
Default Landing gear covers (snap on)
I trust everyone had a good T-Day. Have a question, has anyone had any difficulty in snapping these things onto the grea strut. I got one on ok but the second one will not snap. I understand that they need to be snug and I have been reluctant to put lube on the edge of it. Maybe I just need to warm it up a bit. It was quite a bit warmer in the shop when I put the other one on. Or maybe I just am not putting enough pressure on it, afraid of breaking it. I'm doing with the gear down so that I can get pressure from both sides. Thanks.
Old 11-27-2016, 06:01 PM
  #398
vatechguy3
Got 2 more flights on mine today.
Sealed the elevator hinge gap as suggested. Also, tigtened the elevator covering. No issues with flutter today.
Overall, the plane flew much better today. Tracked strighter and bobbled less.
End of second flight, landing gear failed to cycle. Flew around a few times and tried cycling multiple times and no result. Brought her in for a belly landing. i stopped the prop just before touch down and my buddy found a soft spot. i have no idea how, but escaped with no damage.
found the retract wire disconnected from the receiver. Going to have to safety wire that in place.
Tony
Old 01-11-2017, 03:45 PM
  #399
COL J
HI Chris, I am finally getting around to putting mine together. Did you leave the brass tube a little space on the bulkhead end or did you leave the brass tube long enough so that it slips in a ways into the plastic tubefor so that the sharp edge of the tube to catch on the end of the plastic control rod tube when moved by the servo. I also assume that you used the screw on and soldered on metal clevices that came with the plane. I am using the same engine that you did. Was going to use a Saito FG57TS twin but didn't think it would put out the power I wanted, besides, the 55 isa much cleaner install. I also installed a small piece of brass tube into the Rudder balsa block and hardened it with CA and it gets epoxied on the rudder when iti is installed. Thanks John
Old 01-11-2017, 04:19 PM
  #400
Chris Nicastro
Hi Col J,
What I did was to allow a small amount of the brass tube to enter the plastic tube but I filed the solder like a cone shape to ramp in and out smoothly. I left the clevis adjustable and I use Sullivan with clips.
What are you doing about the cowl for 84?
I opted to use a modified H9 cowl.
