Reload this Page >
T-3 Pics and Build
T-3 Pics and Build
Old 01-18-2018, 09:21 PM
  #126
Digital Pilot
Digital Pilot's Avatar
Mine should be here in a couple days.. Purple Monster....
Old 01-18-2018, 09:22 PM
  #127
clavin
clavin's Avatar
Originally Posted by jsnipes
I am using the Spark Hobby lighting system. Spark Hobby for all the details. Very nice, BRIGHT and inexpensive lighting system. Designed and sold by a friend of mine here in SC.
Which spark hobby kit did you use?
Old 01-19-2018, 07:27 PM
  #128
clavin
clavin's Avatar
Fin/Rudder servo and linkage assembly. Red beacon added to top of fin.
Using BK Servo BLS-8001HV's ... these are high torque, very fast brushless servos. www.bkservo.com
Specs:
High Torque Brushless Servo
Model 8001HV
Operation Voltage: 6V – 8.4V
Weight: 65g (2.29 Oz)
Torque: 25.8 kg/cm (358 oz/in) @ 6V 29.5 kg/cm (409.5 oz/in) @ 7.4V 34 kg/cm (471.9 oz/in) @ 8.4V
Speed: 0.12 sec/60 @ 6V 0.09 sec/60 @ 7.4V 0.08 sec/60 @ 8.4V
Dimensions: 20x40x37 mm
Frequency: 1520us/333 hz
Gear Type: Metal
Motor Type: Brushless
How did you attach the servo brackets to the plywood underneath?
Wood Screws?
CHris
Old 01-19-2018, 09:04 PM
  #129
Digital Pilot
what part, The stab?
Be very careful not to use to long of screws there as you will go through the skin..
Old 01-19-2018, 09:18 PM
  #130
clavin
clavin's Avatar
Yeah and the ailerons...
Just wood screw them into the plywood???
Old 01-19-2018, 09:20 PM
  #131
Digital Pilot
Yes. measure and use the proper length screws
Old 01-19-2018, 09:22 PM
  #132
Digital Pilot
pre-drill with a small pilot drill as to minimize splitting but dont drill through the wing
Old 01-20-2018, 08:21 AM
  #133
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
The proper screws are in the hardware pack?
Old 01-20-2018, 05:45 PM
  #134
jsnipes
I think Eric just has one type.. He can program it however you want. Mine is setup like a scale jet ... if you want that just tell him to do it like mine. Landing light turns on/off with gear. JS
RC Lighting ? Spark Hobby
Old 01-21-2018, 04:42 PM
  #135
Ruizmilton
My Feedback: (29)
Ruizmilton's Avatar
Anyone in the states with a T3 airframe who decided not to build and want to sell? Let me know, I want to buy one, but not wanting to have to wait and wait.
Old 01-21-2018, 06:19 PM
  #136
flejter1
flejter1's Avatar
Contact me at [email protected]
Dirk
Pacific RC Jets
Old 01-23-2018, 05:06 AM
  #137
clavin
clavin's Avatar
Hey man did you get the Purple Monster yet?
Old 01-23-2018, 07:01 AM
  #138
Digital Pilot
Received one box, (center section) and the other two should be here today.....
Old 01-23-2018, 03:21 PM
  #139
clavin
clavin's Avatar
OK.. Starting to build! Here are some pics of masking and paint.. Also laying out the servos..
Name:	2018-01-23 18.05.28.jpg
ID:	2252020   Click image for larger version
Name:	2018-01-23 18.05.22.jpg
ID:	2252021   Click image for larger version
Name:	2018-01-23 17.36.56.jpg
ID:	2252022   Click image for larger version
Name:	2018-01-23 17.36.37.jpg
ID:	2252023   Click image for larger version
Name:	2018-01-23 17.36.27.jpg
ID:	2252024   Click image for larger version
Name:	2018-01-23 17.36.00.jpg
ID:	2252025   Click image for larger version
Name:	2018-01-23 17.35.32.jpg
ID:	2252026   Click image for larger version
Name:	2018-01-23 17.35.53.jpg
Old 01-23-2018, 09:03 PM
  #140
clavin
clavin's Avatar
OK Guys .. Stupid question time.. I have 3 sets of matching push rods.. They are for aileron, flaps and elevators.. But which is which? Also I assume the REAL short one is nose steering.. Then that leaves 2 long ones one is for rudder (But which one?) WHAT is the OTHER one for?
Name:	2018-01-23 23.57.37.jpg
Old 01-25-2018, 04:48 PM
  #141
Digital Pilot
All... I recommend ether adding another hinge on the door front or doing an 80/20 style and hinging the nose door at the very front. if you drop your gear at to fast of speed you could brake the front off of the door..
Old 01-25-2018, 05:29 PM
  #142
David Searles
My Feedback: (49)
I hysoled a 1/8 carbon rod to the inside center of the door from just short of the front to approx 1/2 way back. It won’t break that carbon rod!
David S
Old 01-25-2018, 05:42 PM
  #143
Digital Pilot
Yes, I think that will work as well. Structure of some sort.... Did you fly it yet Dave?
Old 01-25-2018, 05:43 PM
  #144
clavin
clavin's Avatar
They beefed up the door on the T1 just for that reason
Old 01-25-2018, 09:39 PM
  #145
David Searles
My Feedback: (49)
Not yet. Went to Winter Warbirds. Maybe in the next week or two. No rush.
David S
Old 02-09-2018, 09:18 PM
  #146
Westwindpilot86
I have talked to Dirk and I have decided to take the Purple monster jet and they are going to use the green monster as a company show jet. Looking forward to getting it very soon. Going with either a 210 or 260. Futaba 9157`s, Powerbox Mercury and pulse lipos for power.
Old 02-10-2018, 10:24 PM
  #147
Digital Pilot
Another perfect maiden!
My CG is close to 340mm and really like it.
All Savox 1230 Servos
PRCJ wire harness
Kingtech 210
Spektrum radio with telemitry
KT 6.6 & 9.9 3800 Life Packs
ALL electric landing gear and brakes
Factory installed lights
KT Smoke system
Amazing jet!
ID:	2254157   Click image for larger version
ID:	2254158   Click image for larger version
ID:	2254159   Click image for larger version
ID:	2254160   Click image for larger version
ID:	2254161   Click image for larger version
ID:	2254162   Click image for larger version
Old 02-10-2018, 10:26 PM
  #148
Digital Pilot
More....
ID:	2254166   Click image for larger version
ID:	2254167   Click image for larger version
ID:	2254168   Click image for larger version
ID:	2254169   Click image for larger version
Old 02-10-2018, 10:28 PM
  #149
Westwindpilot86
Jeez, you built that jet quickly. Just a week ago i was talking to dirk about getting the purple one. Fast building. How does it do with the 210? Im in the air between the 210 and 260.
Old 02-10-2018, 11:07 PM
  #150
Digital Pilot
Its a fast build. Not much hard stuff to do and it's all electric gear and brakes.
210 flys it well but i think the 260 will be perfect power for it.
