Welcome to Club SAITO !
Old 12-14-2012, 02:51 AM
  #23826
Rudolph Hart
Rudolph Hart's Avatar
Default RE: Welcome to Club SAITO !
The printwood flat balsa sheet parts were fun to cut out and assemble,if it flew even better.Thank Gawd big saito's wer'nt around back in those days
Old 12-14-2012, 08:35 AM
  #23827
JNorton
JNorton's Avatar
I must be a young buck. I only remember gas at 13.9 cents a gallon!
John
Old 12-14-2012, 12:55 PM
  #23828
FNQFLYER
Print wood kits, I have some of them in the kit rack, Flightline I think.  Fleet Biplane scale thing and Marutaka / Royal kits are my thing.  But that is for another place.  I am on the trail of some Saito open rockers (who wants those old things, no power etc) Oh well who am I not to take notice of the needs of others to de clutter their workshops.  Where I live there are lots of old modellers and their sons and grandsons.  It is the later 2 groups that in some cases have no apreciation for "the old things" and as such seek to "get rid of them"  I have been able to return to the O/Timer scene a number of old spark ignition and diesel engines all of which are employed as the makers intended.  I even found a K6 OS engine a while ago (pristine N.I.B.).  But the hunt is on for the Saito open rockers, will eport back if successful in acquiring same.
Old 12-14-2012, 02:48 PM
  #23829
jkr_1100
My Feedback: (15)
jkr_1100's Avatar
ORIGINAL: FNQFLYER
Print wood kits, I have some of them in the kit rack, Flightline I think. Fleet Biplane scale thing and Marutaka / Royal kits are my thing. But that is for another place. I am on the trail of some Saito open rockers (who wants those old things, no power etc) Oh well who am I not to take notice of the needs of others to de clutter their workshops. Where I live there are lots of old modellers and their sons and grandsons. It is the later 2 groups that in some cases have no apreciation for ''the old things'' and as such seek to ''get rid of them'' I have been able to return to the O/Timer scene a number of old spark ignition and diesel engines all of which are employed as the makers intended. I even found a K6 OS engine a while ago (pristine N.I.B.). But the hunt is on for the Saito open rockers, will eport back if successful in acquiring same.
I think we can figure out how to make airplanes fly with open rocket engines. we might not be hovering over the middle of the flight line. but we will still have fun i bet. happy hunting to you sir.
Old 12-14-2012, 04:20 PM
  #23830
greatlakesgunny
My Feedback: (8)
Ooooooh rockets YES!  GIMME!  Rockets make fire, fire cook meat, fire good.
Old 12-14-2012, 05:17 PM
  #23831
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Can any of you Saito Dudes place this unusual looking Saito, Thanks. I know that the rocker covers are the new after market ones but look at that intake pipe. Early 1.20 or 1.50 maybe?
Old 12-14-2012, 06:29 PM
  #23832
w8ye
My Feedback: (16)
w8ye's Avatar
That is the first model of the 120S
Old 12-14-2012, 06:42 PM
  #23833
Rudolph Hart
Was going to say nope but i think the carpet is axminster then i changed my mind
Dave have you ever recorded the temp difference between those rocker covers and the standard ones at the head?
Old 12-15-2012, 06:01 AM
  #23834
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Jim, where you been bro?
OF, I don't fool around with checking temperatures, to me that is a total waste of time.
Gunny, my Dad tried a Poly Choke once on a Remington shot gun. He soon realised that it was a waste of money and the barrel was ruined when they cut a couple of inches off of it.
Saitos are so straight forward that very few gadgets and gizmos effect them, the TurboHeader is one that is a worthwhile addition. This velocity stack I made to replace the intake horn I chopped off to clear the firewall on a RCM 40 did notheing for performance, it did not change the performance either.
ID:	1830160   Click image for larger version
Old 12-15-2012, 07:09 AM
  #23835
greatlakesgunny
My Feedback: (8)
Ah yes the good ol polychoke, sometimes I think it was a decent idea, then I wake up....
Old 12-15-2012, 07:16 AM
  #23836
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
This idea didn't work eithe, nor did moving the crankcase vent to the cam cover. I guess that makes it an idea whose time never came.
Old 12-15-2012, 08:13 AM
  #23837
blw
blw's Avatar
Gunny, you are on to something.
You only put bayonets, bigger clips, and scopes on guns. (slings count as being part of the rifle)
You only put velocity stacks and turboheaders on Saitos. And props.
You can put girls on motorcycles, but only on the back of them. No windscreens, saddlebags, extra lights, etc.
Old 12-15-2012, 08:55 AM
  #23838
earlwb
earlwb's Avatar
Hobbsy, yeah that crankcase vent on the cambox looks good. But it may or may not work as expected.  But that fitting is a good idea, as you can use it to squirt some oil into the cambox from time to time.
Old 12-15-2012, 05:21 PM
  #23839
Rudolph Hart
Well those finned rocker covers may have the right amount of bling for some,was thinking if they do have a cooling affect i'd fit them to my gas twin to help with exhaust gas temps.Also have a couple of tightly cowled glo saito's that may benefit some.
Old 12-15-2012, 05:55 PM
  #23840
FNQFLYER
I have been wondering about those "pretty" rocker covers.  One might be moved to do some tests however I think red rocker covers on my competition models would get me laughed of the field and be a demerit point or 2 on the scale jobs with the cylinder hanging in the breeze (out of the cowl)
Old 12-15-2012, 06:04 PM
  #23841
SrTelemaster150
SrTelemaster150's Avatar
ORIGINAL: earlwb
If you put an inlet check in the back cover & an outlet check on the cam case it does a wondefrful job of forcing fresh lube over the main craink bearing & the cam lobes.
A similar system is used on the 300TTDP for fuel pumping as well as the 220 Big Bore Carb.
Even on 15 Cool Power I saw significant throttle response & prop spool up improvents W/the 220 BB Carb W/pump in my FA180HC/CDIBBC engine. It made 3.95HP W/an 18x10 Dynathrust @ 8950RPM burning O'Donnels 30% Speed Blend 8% oil.
Even @ 8% lube the pump forced plenty of oil through the cam housing.
BTW, the (brand name) Poly-Chokes worked OK. They just looked like crap & were supplanted by the screw-in choketubes.
  #23842
Rudolph Hart
Yes i'm going to hide mine in the cowl if i can.Hoping somone here has tested them re heat dissipation...sr telemaster??
Old 12-15-2012, 07:36 PM
  #23843
SrTelemaster150
ORIGINAL: Old Fart
I don't think heat dissapation would be significantly changed, but sludge formation should be reduced tremendously by thwe positive exchange of crankcase gases. I still have slight WOTsurge while the fuel level is high & I won't be able to do any more testing for a while.
I had my right knee sawed off last monday for a total replacemnt so right now I'm in the "old folks home" for rehab. Took me 3 days to get imternet clearance, still no youtube or FaceBook!
They said they didn't like my looks & disruptive attitude!
Old 12-15-2012, 08:29 PM
  #23844
triumphman49
My Feedback: (149)
Did LMAO, Sr,
So sorry to hear of your surgery, and am praying your recouperative powers are as stout as your wit.
Take care & get home for the Holidays.
Merry Xmas
T-man49 in Al
Club Saito 723
Old 12-15-2012, 10:21 PM
  #23845
Ernie Misner
Ernie Misner's Avatar
Hobbsy, do you get a few more rpm's with the Turbo Header or just the sound? I keep thinking about trying one.
Old 12-16-2012, 04:47 AM
  #23846
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Ernie, on all the Saitos except for the 1.25 there is a gain of 190 to about 300 rpm depending on which one. For some reason the 1.25 does not respond to the TH. I've said often that the 1.25 is a 9,000 rpm thumper no matter what prop you put on it, within reason of course.
Old 12-16-2012, 05:26 AM
  #23847
Rudolph Hart
Ernie they are much lighter than the standard saito system,wait till you see the awesome tig welding
Old 12-16-2012, 05:49 AM
  #23848
blw
blw's Avatar
Ernie, they sound good too.
Old 12-16-2012, 06:18 AM
  #23849
RC Specialties
We have many happy customers. "Nothing sounds like a TurboHeader". Thank you for the kind words.
Merry Christmas to all.
Jim
Old 12-16-2012, 02:07 PM
  #23850
FNQFLYER
Comment o the mods I have seen lately.
The velocity stacks can improve fuel consumption.  Saitos tend to spit fuel at times, the velocity stack will retain those small amounts (very critical in Texaco events)
The staight line intake.  A measured intake length can improve rpm figures but it has to be very carefully matched to engine.  Has been done here on numerous OS four strokes however the increase isn't worth the effort on a Saito in my opinion.
On these turbo mufflers they look similar to the new mufflers that Saito is fitting to the current crop of engines.  Comments please.
Also in a local magazine it is said Saito is recommending a particular brand and type of oil, Klotz R50 principally for the gas engines but also for the "normal" 4 strokes.  It is a racing synthetic marketed by the local Saito agent (distributor)   Likewise comments please
