Welcome to Club SAITO !
Old 09-06-2007, 10:32 AM
  #8426
scratchonly
Default RE: Welcome to Club SAITO !
Richen up the low speed and see if it improves. Too lean low speed can cause problems.
Old 09-06-2007, 10:45 AM
  #8427
plasticjoe
My Feedback: (22)
plasticjoe's Avatar
By Chance anyone looking to part with a 125 ?? I have a 91 that I would trade + cash..... I have an Ultimate Bipe that just needs a little more power in it.
Old 09-06-2007, 11:26 AM
  #8428
jb86
My Feedback: (8)
i just run the throttle pushrod (i use 1/16 wire) past the throttle arm, about 1/4" or so above. run the wire about 1 - 1/2" beyond, make a 180 bend andcome back using a z bend in to the arm. this allows flex and allows the wire to line up as it needs. the servo end i use a harry higley servo connector, it has 1/8" diameter pin into the wheel and a good clip, never a problem.
jon
Old 09-06-2007, 03:39 PM
  #8429
kryptonite
Skillet, I doubt its the fuel. You don't seem to have a problem starting it - bad fuel usually is hard to start.
Almost always, when an engine dies when it is going from mid to full throttle - it has insufficient fuel. I think you've probably tried richening both the LS and HS needles. The Saito runs really well even when absurdly rich, so don't be afraid to open up both needles a lot.
If both the LS and HS settings don't help - the fuel delivery system is probably suspect.
Is the fuel bubbling or frothing from the vibrations?
Is the fuel line kinked anywhere?
Can you blow on the tube on the vent side of the tank and easily force fuel to stream out the delivery side?
You might also want to try 1/8" tubing instead of the normal 3/32" tubing.
I seen issues like these to cause glow engines to stumble and die when going to high throttle even when the mixtures are set correctly.
I only have one Four-Stroke so far, the 125, and it is by far the most reliable and best running engine I have ever owned - so what you are experiencing on two new engines is indeed very strange.
Old 09-06-2007, 04:48 PM
  #8430
RC Specialties
w8ye,
I have heard the ceramic bearings mentioned several times. Who makes them and do you recommend them over the stock bearings? If so, what are the advantages and/or disadvantages? I have a 1.80 that may need a forward bearing.
Jim
Old 09-06-2007, 05:27 PM
  #8431
Garthwood
Hoping somebody will be willing to help me out on this question...............I'm sure it is somewhere in this thread, but 413 pages is no easy thing to read through all.
I'm running a Saito .72 on my Funtana .40. APC 14 BY 4w PowerMaster 15/20 all synthetic fuel. At full throttle Tach reading is about 9500-9600 rpms. While flying, I don't see any difference in increased power from half throttle to full, almost feels like gutless beyond half power. This at level flight. Take offs feels OK.
I've checked fuel lines, glow plug, valve clearance, compression feels OK, fuel is fresh. I don't know what the field's altitude is.
Anybody out there ever had this experience ?. I only have Saito engines. I suddenly noticed this change in power.
Charles.
Old 09-06-2007, 07:00 PM
  #8432
blw
blw's Avatar
Charles- it could be too rich. Or, too much prop. I've not used this prop.
Old 09-06-2007, 08:13 PM
  #8433
skillet92
BTW it was the fuel. It was a new jug of fuel but i tried another jug and it ran perfect. Only about 8500 or 8600 rpm but it stayed there. Thanks for all the advice. I did install a new tank that i had around.
Old 09-06-2007, 08:33 PM
  #8434
Tbone4life
Tbone4life's Avatar
ORIGINAL: RC Specialties
w8ye,
Jim
Try this link, http://www.bocabearings.com/default.aspx
Old 09-06-2007, 09:04 PM
  #8435
jb86
My Feedback: (8)
rc-bearings.com has ceramic bearings.
jon
Old 09-06-2007, 09:20 PM
  #8436
TimC
TimC's Avatar
I just read this warning at the Boca web site concerning ceramic hybrid bearings: "Note: Not recommended for engines that have excessive side or thrust loads. Ceramic Balls are extremely hard and excessive side load may destroy the retainers causing these very hard ceramic balls to cause damage to your engine. Consult your Boca Bearing Sales Rep for additional details or best suggestions."
Does anyone have any info on what could be considered "excessive side or thrust loads"?
Old 09-06-2007, 09:34 PM
  #8437
jb86
My Feedback: (8)
paul at rc-bearings.com will recommend them. never hammer them putting them in, go into a hot case.
lighter, roll smoother, and not much chance of rust - stainless and ceramic.
jon
Old 09-06-2007, 09:41 PM
  #8438
w8ye
My Feedback: (16)
w8ye's Avatar
I've been buying the ceramics from Paul for about a year now. They seem pretty nice to me. No problems so far. I observed all the precautions.
Old 09-07-2007, 07:07 AM
  #8439
RC Specialties
Thanks to all.
Jim
Old 09-07-2007, 07:28 AM
  #8440
w8ye
My Feedback: (16)
w8ye's Avatar
Jim,
I recommend the Ceramic bearings for any more expensive engine that you enjoy and plan to keep.
Old 09-07-2007, 05:47 PM
  #8441
Garthwood
Blw.............thanks I'll check this out.
My CG Ultimate 10-300 Blue Hawk has a Saito 120 with about 10-15 flights on it. Plumbed with a three line. Third line being a Fuel Dot to fuel up and defuel. The third line goes all the way down to the bottom of the 16 ozs. tank being located to the front and bottom of the tank. To fuel up I use a Dave Brown fueller or sometimes the Du-Bro hand crank. At the start off of fuelling there is a small amount of fuel that comes out of the muffler, then it stops and continues to fuel up. I was wondering what's causing to do this. I checked out all the lines and everything looks OK. Anyone experienced this ?
Thanks.
Charles.
Old 09-07-2007, 06:38 PM
  #8442
w8ye
My Feedback: (16)
w8ye's Avatar
There's some liquid in the muffler line. When you start to refill, it blows the liquid out of the line?
Old 09-07-2007, 07:36 PM
  #8443
RC Specialties
Garthwood,
I have the same plane, engine, and setup. If the muffler vent points up in the tank, then I have to agree with W8YE. I have not experienced this problem but I defuel when finished flying. Perhaps you are not completely defueling. If there are no other problems I wouldn't be too concerned.
Jim
Old 09-07-2007, 11:50 PM
  #8444
kwjames
Thanks Jon for the come back.
Ken
Old 09-08-2007, 07:13 AM
  #8445
fredira
I have 2 Saito 56 & A 180
One in a Kadet Senior and the other in a cap 232.
My 180 is in a 3-D Obsession, so can I be in the club ?
Thanks Fredira
Old 09-08-2007, 07:15 AM
  #8446
fredira
Thanks Fredira
Old 09-08-2007, 05:03 PM
  #8447
3D Aviator
Is their a velocity stack that will work on the fa 100? If so please tell where i can find it and the benifts of having one. Thanks for the help!!!
Old 09-08-2007, 06:51 PM
  #8448
w8ye
My Feedback: (16)
w8ye's Avatar
There is only one velocity stack for the medium Saito's. One size fits all . . .
http://www.horizonhobby.com/Products...odID=SAI50GK93
Old 09-08-2007, 09:51 PM
  #8449
Safebet
My Feedback: (12)
Question about a Saito 56. A very fine flyer maidened my GP 1/6 J-3 Cub for me today. Flew twice. On the second flight it flew great, sounded good. He landed
and taxied up to the fence. I retrieved the plane put it up on the table. About 5 minutes later another RC'er came by a flipped the prop. No Compression. He thought maybe it was too lean, got hot and a valve stuck or a dry cylinder.
What do some of you think. I am going to pull the valve covers tomorrow and take a look. On occasion when you flipped you could feel slight compression and then it would feel free, again. ???? This is my first experience with Saito. I have a Magnum .91, but have flown it very little. I don't have any 4-stoke experience.
Old 09-09-2007, 12:09 AM
  #8450
blw
blw's Avatar
Jim,
Sounds like you had the throttle closed. Check your compression with the throttle open.
(I had a stick buddy in flight school named Jim Vines)
