Welcome to Club SAITO !
Old 08-21-2007, 09:18 PM
  #8276
swixtt
swixtt's Avatar
Default RE: Welcome to Club SAITO !
hmmm never heard of that stuff... i'll have a look! thanks for the info. i never would consider sanding it!
is it a normal occurance to have get discoloured from the oil? should i seal it up better with teflon or something?
thanks again weight
Old 08-22-2007, 02:12 AM
  #8277
AKFireMedic
AKFireMedic's Avatar
Thanks for the help everyone!
Old 08-22-2007, 03:13 AM
  #8278
XJet
Banned
ORIGINAL: swixtt
Yep, especially if you use a little castor in your fuel (which you should).
My Saito 82 has a really crusty muffler but the one on my 100 is a lot cleaner.
When they get *really* bad I'll just take them off and do the crock-pot/anti-freeze thing to them, then they'll be good for another couple of years.
Old 08-22-2007, 07:46 AM
  #8279
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Now days I disassemble the mufflers before running and wrap Teflon Tape in the the joint and around the muffler bolt as well as both ends of the pipe.
Old 08-22-2007, 02:52 PM
  #8280
boogermancan
boogermancan's Avatar
what all comes out of pipe baffels or is it empty in side
Old 08-22-2007, 03:05 PM
  #8281
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It is empty inside except for the bolt.
Old 08-22-2007, 04:54 PM
  #8282
edberg
edberg's Avatar
I got some "PTFE Thread Seal Tape", which I'm guessing is that Teflon Tape you guys were talking about, so I just wrap it around the thread once tightly and screw it in normally?
Wrap It tight, loose, once, twice?
Old 08-22-2007, 05:11 PM
  #8283
RC Specialties
edberg,
You should apply teflon tape two complete wraps around the threads in the same direction you would screw on the jamnut. Install as normal. Check the package to see if it is teflon tape. Teflon tape can be found at any hardware store. It is usually white.
Jim
Old 08-22-2007, 05:12 PM
  #8284
RVM
Tightly, twice or thrice.
ORIGINAL: edberg
Old 08-24-2007, 06:07 PM
  #8285
rainedave
rainedave's Avatar
Hi, before I scan through 405 pages of posts can someone tell me if this thread contains a chronology of Saito single-cylinder engines? I'm interested in learning the order in which all the various models were released: which models are the oldest, newest, ect.
David
Old 08-24-2007, 06:53 PM
  #8286
rchotrod
rchotrod's Avatar
Hi everyone, You could say that I am joining Club Saito with both fe, er cylinders. I am in the process of purchasing a 90t. The older one with the V rockers. It will have a home on my good ol' Blue Max. It flies around now with a magnum 52 4stroke. But the 90 twin will really liven it up. Any way to run longer exhaust pipes on the twin? I have a buddy at a welding shop who has some tubing and I thought it would be neat to have a shiny polished pipe along each side of the plane. Sorta like dual exhaust side pipes on a car. Will I still need to add a pressure tap to one pipe? Will it hurt to have the pipes extend back to below the wing?
Just tossing ideas up to see what flies.
See ya,
Rod
Old 08-24-2007, 07:28 PM
  #8287
w8ye
My Feedback: (16)
w8ye's Avatar
Four strokes are not as sensitive to long pipes as two strokes are.
You can try it without muffler pressure? You can always add a tap?
Old 08-24-2007, 07:47 PM
  #8288
w8ye
My Feedback: (16)
w8ye's Avatar
There's no direct chronology of Saito's in this thread.
I'll get things started but don't have dates. These are the singles. This may be out of order? I stand to be corrected. It will get things going? Naturally there are variations to these as time and evolution took it's toll?
Corrections contributed by others are in read?
10cc two stroke (1955)
30 open rocker separate head. (1979)
30 open rocker one piece cylinder
Saito 40 separate head (1980)
Saito 120 (1982) There were some variations on the carbs so there very well may have been a MK I and a MK II?. Also they've been around a while and some parts from the 120S will fit under certain conditions, so you may see engines that are half 120 and half 120S?
Saito 40 one piece cylinder MKII?
Somewhere in here the 65 came around?
Saito 80 The early ones had high compression
Saito 45
Saito 45S
Saito 50 The 50's have been around a while. There are two different Cylinder designs, two different carbs, two different back plates, two different crankshafts, Three different crankcase designs, and about 6 different mufflers.
Saito 91S
Saito 120S There are two different designs of the intake pipe on these
Saito 150S The early ones had high compression (1991)
Saito 56 (1996) Even the 56 had three different crankcase designs
Somewhere right in here the 30 as we know it now came about? 1998
Saito 180 (1999)
Saito 72 (2000)
Saito 100 (2001)
Saito S40 (2002)
Saito 82 (2004)
Saito 220 (2005)
Saito 125 (2006)
Saito 62 (2007)
Twins
80T 1981
90T
130T
60T
100T
270T ?
182TDP
90TS (1998)
There's two 300's Single carb and dual carb
100Ti
200Ti
Radials
325R5
450R3
170R3
90R3
I'll edit this list to correct any errors as they are pointed out?
Old 08-24-2007, 08:06 PM
  #8289
rainedave
rainedave's Avatar
Wow! Thanks w8ye! That's exactly what I want to find out. So, I guess the .62 is one of the newest releases?
Thanks for the info.
David
Old 08-24-2007, 08:10 PM
  #8290
w8ye
My Feedback: (16)
w8ye's Avatar
That is correct but I forgot to put it on. I edited the post to include the 62. -Thanks-
Old 08-24-2007, 08:46 PM
  #8291
blw
blw's Avatar
The best timeline that I found on the Saito website has this:
1979- FA 30
1980- FA 40
1981 FA 80T
1982 FA 180
2004 FA 82
2005 FA 220
Old 08-24-2007, 09:21 PM
  #8292
w8ye
My Feedback: (16)
w8ye's Avatar
That 1982 just about had to be the old style straight 120?
Click on Modification of Company Organization
http://translate.google.com/translat...ial%26hs%3DCB8
The 180 I don't think came out until around 1999?
Old 08-24-2007, 09:52 PM
  #8293
rainedave
rainedave's Avatar
It looks like the oldest model Horizon is selling is the .91. Have the 40, 45, 50 and 120 been discontinued?
David
Old 08-24-2007, 10:56 PM
  #8294
w8ye
My Feedback: (16)
w8ye's Avatar
Also Horizon no longer sells the 30, A40, 65, & 80
This you are speaking of was announced in May 2007 that Saito themselves discontinued the 50, 65, & 80
Old 08-25-2007, 09:01 AM
  #8295
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Jim, I went through some of my receipts, most of these were bought when they first came out with a couple of exceptions.
.56======9-9-96
.30s=====12-14-98
1.00 GK==12-20-01
.82 GK===5-17-04
1.25 GK==12-27-05
.62=====12-18-06
.50=====12-6-02, one of the last.
I no longer have the receipts for the .72 or .91 GK nor do I have the engines any longer.
Old 08-25-2007, 09:22 AM
  #8296
Rv7garage
My Feedback: (10)
Don't forget that somewhere in there Saito actually produces some -say it softly- 2-stroke boat engines![sm=bananahead.gif]
Old 08-25-2007, 09:45 AM
  #8297
blw
blw's Avatar
Jim,
Yes, that was a typo on my part. That is where I got my information too.
Old 08-25-2007, 01:34 PM
  #8298
Kmot
My Feedback: (24)
Kmot's Avatar
Sounds of Saito:
http://www.horizonhobby.com/Articles...ArticleID=1706
Old 08-25-2007, 04:07 PM
  #8299
jessiej
ORIGINAL: blw
Jim,
I must confess; were I given a comprehension test on that website I fear I would not do too well.
jess
Old 08-25-2007, 08:28 PM
  #8300
blw
blw's Avatar
The translation is poor. I think I'll try it through another translator site because they mention something about the .56, and I want to be sure what it says. I really like that engine a lot.
