Welcome to Club SAITO !
Old 10-12-2015, 04:14 AM
  #30176
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by SigMan
i love this thread
Who are you?
Old 10-12-2015, 04:21 AM
  #30177
Rudolph Hart
Barry never mention speed shops and woodstock in the same post,it's the flashbacks that hurt the most nowadays.
He's right popey you are being insensitive.I had a backscratcher that was a small roos arm claws and all,only time i felt safe really but thats a whole other story.
Old 10-12-2015, 07:20 AM
  #30178
blw
blw's Avatar
I'm not clicking on that link, Pope. I don't trust you.
We had a mule on our field for a while. He once tried to gnaw my tail light cover and I had to chase him off. He bit me lightly on my pants pocket once and he got hit on the head. He probably was used to kids carrying apples in their pockets to feed him. I started taking fireworks out to the field to chase him off the runway. He got used to bottle rockets and I would sometimes have to fire half a dozen at him before he got irritated enough to move. He had a bit of a mean streak in him.
Old 10-12-2015, 08:23 AM
  #30179
aviation421
My Feedback: (68)
Hello everyone,
I have a Saito 1.80 and I know they are glow thirsty
so my question is...
What do you recommend...Convert to CDI Glow or Convert to Gas
Thank you
John
Old 10-12-2015, 09:07 AM
  #30180
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by aviation421
Hello everyone,
Thank you
John
If you are willing to sacrifice 20% of the HP, put up with the stench & fire hazard, go ahead & convert to gas.
If you want 25% better fuel economy, vastly improved user friendliness with a slight boost in power, convert to CDI & continue to burn glow fuel.
If you want 25% better fuel economy, the same vastly improved user friendliness & as much HP as an FA-220 put an FG-57 piston in it to boost compression, convert to CDI & continue to burn glow fuel. The FG-57 piston is a no modification required upgrade & you can even uses the same ring.
This was my 1st prototype built on an FA-150 case. You can get nearly the same power by just swapping the FA-180 piston for the FG-57 piston.
https://www.youtube.com/watch?v=5xaiAR8Yelc
My suggestion is to CONVERT TO CDI & try it with glow fuel.
If you decide you still want to go to gas despite the significant loss in power, higher operating temperatures & likely shortened engine life, go ahead & get the CARBURETOR FOR THE GAS CONVERSION.
Old 10-12-2015, 01:03 PM
  #30181
Charley
Originally Posted by the pope
No such thing as too much info and just to prove it check these bad boys out
http://www.australiagift.com/scrotum...FYiWvQodA5QFLQ
cheers the pope
Pope, that just tickles the h--l out of me!
CR
Old 10-12-2015, 01:21 PM
  #30182
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Originally Posted by Old Fart
Who are you?
Pete, he started this thread and Is Saito Club Member #1.
Old 10-12-2015, 01:39 PM
  #30183
Charley
cheers the pope
CR
Old 10-12-2015, 03:38 PM
  #30184
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Dan, is that a MA Classic 18x6, Thanks, Dave
At the end I saw 18x8, that's pretty good.
Old 10-12-2015, 04:44 PM
  #30185
the pope
Hi there worm You can get them at most tourist type shops here in aus . In my last post theres a link also where to buy . Just checked the price , definitely aimed to the cashed up ! Might be some cheaper , even China probably make em . You would look a sight thats for sure , definaltly a chick magnet . Cheers the pope
Old 10-12-2015, 06:15 PM
  #30186
the pope
CR
even says there made from the scrotum of the male kanga . If they came from the female kanga the coins would just fall out ! cheers
Old 10-13-2015, 02:22 AM
  #30187
SrTelemaster150
It's a Dynathrust 18 X 8. You should see what it does with the 12mm carburetor. 8450 RMP on 15% Cool :Power, 8950 RPM with 30% O'Donnell Speed Blend (8% lube)
Old 10-13-2015, 05:21 AM
  #30188
Rudolph Hart
Thanks dave i only said that in the hope that sigman would find it funny.Maybe speak up and say a bit.It's an aussie sense of humour take the pee out of someone you like,and is always in good humour.Now, if you still feel like firing a round through my buttocks i offer the streakers defence after he had been arrested the night before and was appearing in court the next morning...'it seemed like a good idea at the time your honour'
Click on it barry.Popey do you remember months ago we were discussing how mountain oysters were produced? i reckon your missus has 'ringed you' and yours are swinging off her rear view mirror
Old 10-13-2015, 05:46 AM
  #30189
FlyerInOKC
FlyerInOKC's Avatar
Hey Okey, did the guy do the high compression part himself, I never heard of an actual high comp0ression .91. Thanks, Dave
This is an interesting read.
~http://sceptreflight.net/Model%20Engine%20Tests/Saito%20FA-91S.html
The compression is a Saito feature that is why its such a rare animal. I guess Saito gave it a try on a limited scale and then decided to keep going like they had been. It was a little harder to tune like a YS.
Old 10-13-2015, 05:51 AM
  #30190
FlyerInOKC
FlyerInOKC's Avatar
CR
I'll bet the Roo wasn't too tickled though!
Old 10-13-2015, 06:34 AM
  #30191
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
No splainin needed Pete, if it's in fun I'm all for it.
Old 10-13-2015, 08:23 AM
  #30192
Charley
My early high compression Saito .80 will kick back and bust your fingers if you aren't careful. I once carried the airplane it was in back to the pits after an uneventful flight, put it down and turned to exchange a few words with a clubmate, then turned back to the plane and for some unremembered reason turned the prop CCW against compression. The danged thing kicked back and gave my fingers a painful jolt! This after having been shut down for 5 minutes or so. Good thing it had a wooden prop on it.
CR
Old 10-13-2015, 01:45 PM
  #30193
Jaybird
Hello,
New to the group but I have been reading a little. Currently operate a Saito 50, 56, 80, 91 (2), 100, 125 and 150.
Recently transplanted a couple of engines and having trouble tuning even though they ran great in the previous airframe.
Saito 91 was inverted, now side mounted won't shut off with idle cut. Looked at the barrel and the linkage. Linkage is free and with it unhooked the barrel still won't close off completely. Same motor is not running clean at full throttle either. Slowly adjusting high speed needle valve.
Saito 150 ran perfectly side mounted in a 1/4 scale Pitts airframe. Now side mounted in a 1/4 scale Cub bogs down anything over 3/4 throttle but runs smooth up to that point. I have checked the tank and have very short new connection lines. I did rotate the needle valve housing with the fuel port 180 degrees to make a straight run to the fuel line.
Suggestions welcome.
Jaybird
Last edited by Jaybird; 10-14-2015 at 05:42 AM. Reason: previously said 90 degrees by mistake
Old 10-13-2015, 02:26 PM
  #30194
SrTelemaster150
Originally Posted by Jaybird
Hello,
Saito 150 ran perfectly side mounted in a 1/4 scale Pitts airframe. Now side mounted in a 1/4 scale Cub bogs down anything over 3/4 throttle but runs smooth up to that point. I have checked the tank and have very short new connection lines. I did rotate the needle valve housing with the fuel port 90 degrees to make a straight run to the fuel line.
Jaybird
Is the "cat's eye" facing the manifold?
Old 10-13-2015, 07:25 PM
  #30195
aviation421
My Feedback: (68)
Thank you Sr Telemaster I am convinced...
I will convert to CDI Glow
Old 10-14-2015, 04:03 AM
  #30196
SrTelemaster150
Set the initial timing at 34-36 degrees BTDC. Start the engine on the GI (glow ignition) carburetor settings. Run @ WOT & lean the HSN a few clicks @ a time (waiting several seconds after each adjustment to allow the RPM to stabilize) until the engine sags. That is your lean limit. Open the HSN a few clicks at a time until the engine sags. That is you rich limit. There will be several clicks, perhaps a quarter turn or more where the RPM won't be affected. Set the HSN a few clicks leaner than the rich limit. Now lean out the LSN as much as you can & still get smooth transition.
Here is a thread that lists FUEL CONSUMPTION for various prototype big block Saitos with CDI. Post #5 has the results listed.
Old 10-14-2015, 04:45 AM
  #30197
FlyerInOKC
FlyerInOKC's Avatar
Pope, this story is right up your alley!
http://www.huffingtonpost.com/entry/...b028dd7ea5381d
Old 10-14-2015, 07:11 AM
  #30198
the pope
Darn tooten , but please refrain from calling my rear man part as an alley ! Thankfully it doesn't get that much traffic and before you ask its a one way street . I see on the bottle it says made in the USA and because its so popular there's none left for export . Cheers the pope
Old 10-14-2015, 09:34 AM
  #30199
blw
blw's Avatar
I did mention that was too much information, didn't I? Now look at what happens around this place.
Pope- we have the same thing over here but from bulls. They pretty much market them the same way.
Pete- I ragged on Sigman too.
Old 10-14-2015, 10:11 AM
  #30200
rcmichael
My Feedback: (21)
Just picked up a 2.20 glow! Also have a 1.25, .82, .62. I haven't run the 2.20 yet, but I am sure it is a beast!
